It is currently Mon Feb 17, 2020 8:00 pm
PostPosted: Fri Feb 05, 2010 11:17 am
Year and Trim: 2003 Se Bonneville
I dont care about chimes. Which harness can i get to power up my head unit? I'm runnin amps for everything just want clean power and key hot. ill find a healthy ground
PostPosted: Fri Feb 05, 2010 8:30 pm
Year and Trim: 2001 SLE
If you get the cheap $15 harness you will have to run a power to the head unit because our radios you a low level signal (dont quote me 100% on that) to turn the radio on. If you get the expensive $80+ harness you wont have to run a power
Night Hawk, The 4 door coupe
2 12" Pioneer Premiers in a vented box $350.00
2200 watt comp mono amp $200.00
7 inch Power Akoustic touchscreen 400.00
Setting off countless car alarms and making my passengers ears bleed... PRICELESS
Bugsi " then you could achieve that with fewer subs and still have (some) trunk space left over to carry groceries/body parts/etc"
PostPosted: Mon Feb 08, 2010 2:09 pm
Year and Trim: 1990 SSE
There is a ground and constant power in the harness. The data module creates the door chime and gives you a switched accessory (red wire) that will make your deck turn on and off just like the factory unit, with retained accessory power (RAP) and all that. You can run your own power and ground, and run a wire from your accessory wire (orange) in the ignition switch to the radio, youll lose the RAP. You can recreate a RAP circuit like this
http://www.the12volt.com/relays/page5.asp#drto
heres an example of the kit you would need, its a BHA2001R. This one is from Bestkits, but there will be an equivalent harness from any other company you choose.
__/"""""\___
"-@--------@--" 1990 SSE " Black Ice " 215,456+ kms,
16" Streetwear Diablo wheels | FWI | Magnaflow cat | '94 top swap | MSD Ignition | Projector Retrofit w/ HIDs | Modded Mesh Grille | STB | Blue interior LEDs | LED 3rd brake light | Dynamat | Woodgrain delete | JVC NX-5000 nav/dvd | Infinity 1230W
http://www.cardomain.com/ride/674760/19 ... bonneville
Last edited by phoenix_flame220 on Mon Feb 08, 2010 2:13 pm, edited 2 times in total.
There are no new unread posts for this topic. 2004 GXP Antenna Adapter for aftermarket radio
techweenie
Mon Jul 14, 2014 7:51 pm
bobgto65 View the latest post
There are no new unread posts for this topic. Aftermarket Stereo
Malibu1993
Thu Oct 10, 2013 1:13 pm
gweg_b View the latest post
There are no new unread posts for this topic. aftermarket stereo
PossessedPower
Sun Feb 27, 2011 2:44 pm
willwren View the latest post
There are no new unread posts for this topic. Aftermarket Stereo in the GXP
SAMzGXP
Sun Mar 29, 2009 5:12 pm
Looong4 View the latest post
There are no new unread posts for this topic. 2000 bonneville aftermarket stereo
Jaymeson123
Fri Feb 03, 2017 12:58 am
redfury View the latest post
