It is currently Mon Feb 18, 2019 2:18 am
Post new topic Reply to topic  [ 64 posts ]  Go to page 1, 2, 3, 4  Next
PostPosted: Fri May 15, 2009 10:32 pm
k so i returned my GMOS-09 and i bought the GM32R and i connected it today..
the module itself chimes whenever i have the key or lights on and YET NO SOUND COMING OUT WHEN THE RADIO IS ON! :angry4: :angry4: :angry4: :angry4: :angry4: :angry4: :angry4: :angry4: :angry4:
im already starting to hate this stupid deck! how the hell can i get it to work!!
UPDATED PAGE TWO
Cardomain link
Fully tinted, 5000K HID hi/lo & fogs, LED conversion (interior/red rear signals/reverse light/license plate/trunk/sun visor/glove box/switch backs), turn signal mirrors, JVC KW-NT3 Navi & BT, KV-CM1 Camera, 2x JL 13TW5, JL G-Max, black & chrome emblem, 20" black & red, clear corners, center tail light up, half tinted tail lights, cross drilled rotors, Hawk ceramic pads, and more..
Black GXP. One of a kind. RIP.
G35 Coupe 6MT. Stockishhh
PostPosted: Fri May 15, 2009 10:45 pm
From the installation guide:
"Designed for vehicles without OnStar® or Premium BOSE® sound systems."
Are you wiring the module directly to your speakers? If not, this is likely the problem. I'd have to have a close-up pic of the 32 pin DNL connector to see what wiring is present, but I'm willing to bet that it isn't wired to support the amp.
PostPosted: Fri May 15, 2009 10:53 pm
there are three wires joined together to the remote wire
i got three pics
the three blue wires under my finger are soldered together to be the remote wire
and this is the box...
it said works with bose or no bose
Cardomain link
PostPosted: Sat May 16, 2009 12:12 am
Yeah, the wording is kinda tricky. Bose "Premium", which is what the installation guide states, usually implies an external amplifier. This however can also refer to a Class 2 amp sometimes which wouldn't apply here since the Monsoon amp is a non-Class 2 amp. A couple of questions...
What do you have the three blue wires that are tied together connected to?
Have you verified that your new head unit works in an environement outside the Bonneville?
It looks like the wiring to support the amp should be there.
PostPosted: Sat May 16, 2009 12:25 am
the three wires were connected together from PAC and never said anything on them.. since its blue and white i assumed it was the amp remote...
so i have it connected to the amp signal wire on the deck
i tested my head unit at a small speaker at work and it worked fine... but never tested it on amps to see if it works..
yet i scanned the remote signal wire coming out of the deck and it gave me 12 v.. which means it works..
i also tried connecting the remote wire in the harness to a 12v source didnt work
im really giving up on this thing already....
Cardomain link
PostPosted: Sun May 17, 2009 2:26 pm
When you say that you connected the remote wire in the harness to +12V, I assume you are referring to the vehicle harness? Can you be specific about which terminal this was (include the wire colour as well).
PostPosted: Sun May 17, 2009 2:30 pm
i connected the blue and white wire on that harness above to the yellow wire that also read +12V think that might help in turning the amp on
Cardomain link
PostPosted: Sun May 17, 2009 2:35 pm
I'm going to have to do a little more research...
PostPosted: Sun May 17, 2009 2:37 pm
thank you i really appreciate it..
do you have a wiring diagram of the stock harness?
Cardomain link
PostPosted: Sun May 17, 2009 5:02 pm
Year and Trim: 2000 ssei
i don`t know if its the same in a gxp but i had to run a remote wire from my hu to the bose amp in the back. it is a pink wire in my 2000 with bose
2000 ssei white debadged, autozone solid front mount, NGK tr55 plugs, Napa Beldin wires, MSD Coils, drilled slotted rotors, monroe max air rear shocks, 18" KMC Hot wheels redline w/ 235/50/18 bfg G-force tires, pioneer DEH-P580mp deck, Infinity Ref 6.5s and 5.25s, Kappa 6x9's on crossfire amp, kappa 12 on kenwood amp, and cleared headlights.
Gumball wrote:
my pockets dont sag and are still kinda tight.
PostPosted: Sun May 17, 2009 5:03 pm
really? and it worked after that?
what kinda harness did you use?
Cardomain link
PostPosted: Sun May 17, 2009 6:11 pm
same one, when ddadler gets back hr should be able to tell us what color wire yours has
PostPosted: Sun May 17, 2009 8:50 pm
I'll post some info later on. The Bose amp is definitely not wired the same as the Monsoon. They are not even close to being pin for pin compatible (at the amp end).
PostPosted: Sun May 17, 2009 8:53 pm
So do you think that would fix the problem if I run another wire to start the emp?
Cardomain link
PostPosted: Sun May 17, 2009 8:58 pm
Based on how it's wired, there's no reason that you shouldn't be able to use the wiring already in place. It's really about how it's wired up at the HU end. Part of the problem may be that the Monsoon amp senses a radio on signal as well as uses the 14V ref line. This is what I need to dig into a little more. The Bose amp doesn't (IIRC). With vehicles that have the Bose amp, one of the inputs on the back of the HU is grounded and this is how the radio knows it's there. It then uses a different signal to turn the amp on. Monsoon amps are a little different.
PostPosted: Sun May 17, 2009 9:23 pm
why is there 3 remote wire on the harness if you don't mind me asking?
Cardomain link
PostPosted: Sun May 17, 2009 11:40 pm
Two of these have to do with the amp. One is related to the 14V Ref signal, one is Radio On Signal and the last is the antenna module enable. Our cars have an antenna module that is part of the Diversity Antenna system and needs to be enabled when the radio portion of the HU is active.
PostPosted: Mon May 18, 2009 2:39 am
so if i wanna run a 12v wire to the amp like swampthing did any idea which one is that?
Cardomain link
PostPosted: Mon May 18, 2009 3:13 am
How about I check this out a little more first :wink: He has a different amp. The computer all my technical documentation is on a different computer. As soon as I can get to it, I'll look over the diagrams. Believe me, I understand your frustration and drive to get this done.
PostPosted: Mon May 18, 2009 3:17 am
lol thanks man i owe you big time...
if i move to calgary i owe you wings or something lol
Cardomain link
There are no new unread posts for this topic. 92-99 Aftermarket HU
3800SERIESII
Fri Nov 23, 2012 5:52 am
Bugsi View the latest post
There are no new unread posts for this topic. Aftermarket
kc9dre
Sun Nov 12, 2017 9:27 pm
kc9dre View the latest post
There are no new unread posts for this topic. aftermarket deck
dontoh
23
3156
Thu Oct 21, 2010 10:52 am
There are no new unread posts for this topic. Aftermarket Gauges
Shae
Fri Feb 18, 2011 4:25 pm
willwren View the latest post
There are no new unread posts for this topic. Aftermarket Headunit - '03 SE
do9105
Thu Apr 23, 2009 1:15 pm
SAMzGXP View the latest post
Users browsing this forum: Google [Bot] and 3 guests
