It is currently Mon Mar 17, 2025 7:34 am
 Post subject: Lifter sticking?
PostPosted: Tue Dec 02, 2008 2:46 pm
Year and Trim: 2009 G8 GT
This recent cold weather is causing the car to shake a bit and sound like an old V8 when I first start it in the morning. I also get a ticking from under the hood that reflects rpm speeds. This all stops once the coolant reaches about ~140-150F (the ticking fades as temps increase).
To me it sounds like the sticky lifter I had in my old 70 Dodge, but I think I'm wrong. Thoughts?
2009 G8 GT - White Hot
FMS Custom Cam, Yank 3600 SS, 1LE (ZL1) 3.91, SLP Longtubes, Magnaflow cat-back, Rotofab CAI, tuned via HPTuners
415/391
 Post subject: Re: Lifter sticking?
PostPosted: Tue Dec 02, 2008 4:26 pm
Year and Trim: ____
Good chance of it. Likely that it's gummed up or that something is holding its check valve open, or something of the sort. Personally, I'd suggest putting seafoam in the oil (amount per instructions on the can) and run it for the rest of your drain interval...and maybe put it in again next time you change it. Good way to break down the varnish that builds up in the crankcase.
To go a little further, there are other oil system cleaners, some are actually a whole system with steps and everything if you really want to clean it all out...but it certainly doesn't end up being very budget friendly...so seafoam might be the best idea...and just keep running it through with every change until it goes away. I know I used it a few times on my sticky lifters on the 89 and by the time I sold it, it was less of the loud clacking that I started with, and ended up as more of a quieter click.
John
PostPosted: Tue Dec 02, 2008 5:32 pm
Year and Trim: 2002 Chevrolet Impala LS
Switch to Amsoil Synthetic :wink: It'll clean your motor out pretty nicely. I can't begin to stress how beautifully brand new my engine looked when I pulled it and tore it down to do the cam swap.
"3.8 Liters of twisted steel and sex appeal" -schmidty on NAIOA
I've got an '04 CompG. Got a Gen V and an intake...... so far
PostPosted: Tue Dec 02, 2008 7:08 pm
Year and Trim: ____
Since I just remembered a very good treatment, I'll post it.
Auto-RX. It's an awesome crankcase cleaner. You run it about 3oz to a quart (1:10.6 ratio)
Details here... http://www.auto-rx.com/pages/fast_track_app.html
John
PostPosted: Sat Dec 06, 2008 7:41 pm
I meant to post in here sooner, but that rough start up you are describing is exactly what happened with my car when the LIM gasket went.
http://www.thechicagogarage.org - Now Home of ILGPC
PostPosted: Sat Dec 06, 2008 8:46 pm
Well it stopped for now.
415/391
PostPosted: Sat Dec 06, 2008 11:05 pm
Ditto here. Mine sounded like a single lifter rattling on a cold morning. It stopped after the LIM gaskets were replaced. Someone on here said it was probably the coolant getting into the oil and thinning it, which allowed it to drain back out of the lifter overnight.
2002 SE 123k mi.
Bosch Super Plus plugs
Alum. LIM gaskets
Dorman UIM
Replaced door watershield seals
PostPosted: Mon Dec 08, 2008 4:17 pm
Thanks for the info. I'll have Intense do an overhaul this spring.
415/391
PostPosted: Mon Dec 08, 2008 5:53 pm
Considering how cold it got over this past weekend, it could very well be a lifter that got starved of oil for a little while. If it starts happening all the time, I'd consider pulling the valve covers and manifold and check the lifters.
PostPosted: Tue Dec 09, 2008 11:35 am
If you want to save yourself a drive to Ohio, have Sinister Drag Design take a look at it. I feel like i'm beating a dead horse every time i bring this up but i can't see driving all the way to Ohio to have a company who hasn't MANUFACTURED a new 3800 part in almost a year and seems to be heading more towards G8's look at your motor, when there's a company that's involved with numerous impressive 3800 builds locally available.
PostPosted: Wed Dec 10, 2008 2:09 pm
I'm sure they are concentrating on the G8, but they still have heavy support for the 3800 because of the huge performance market it provides.
I trust the people at Intense. Nothing against Sinister Drag Design, I've never been there...but an employee at Intense let me stay at their place over night last time I had work done to a car. Talk about service! :)
Also the reason I said I'd have Intense do an "overhaul" is because I plan on having them install a cam. So 2 birds with 1 stone.
415/391
There are no new unread posts for this topic. sticking caliper
Tue Apr 20, 2010 4:36 pm
There are no new unread posts for this topic. Sticking gas pedel or throttle body
albow77
Thu Jun 09, 2011 12:44 pm
albow77 View the latest post
There are no new unread posts for this topic. 2005 SLE Lifter Chatter on Deceleration
rynmcdonald
Mon Jan 13, 2025 9:51 am
J Wikoff View the latest post
There are no new unread posts for this topic. ticking sound...sounds like a lifter or exhaust?!?!
03bonssei
Fri Jul 02, 2010 5:39 pm
03bonssei View the latest post
There are no new unread posts for this topic. lifter tick, runs rough maintanence questions, story
JordanT
Wed Sep 23, 2009 6:11 pm
cron
