It is currently Mon May 20, 2019 6:21 am
 Post subject: icm mounting plate
PostPosted: Sat Nov 29, 2008 1:37 pm
Year and Trim: 2000 ssei
i just noticed my coil is loose does anybody know where to get the mounting plate?
2000 ssei white debadged, autozone solid front mount, NGK tr55 plugs, Napa Beldin wires, MSD Coils, drilled slotted rotors, monroe max air rear shocks, 18" KMC Hot wheels redline w/ 235/50/18 bfg G-force tires, pioneer DEH-P580mp deck, Infinity Ref 6.5s and 5.25s, Kappa 6x9's on crossfire amp, kappa 12 on kenwood amp, and cleared headlights.
Gumball wrote:
my pockets dont sag and are still kinda tight.
 Post subject: Re: icm mounting plate
PostPosted: Sat Nov 29, 2008 1:57 pm
You may be able to find one at a junk yard. Many just get a longer similar sized bolt, and put a nut on the other end.
PostPosted: Sat Nov 29, 2008 1:58 pm
what years have the same ones 2000+ are very rare in junk yards down here i only have seen one
PostPosted: Sat Nov 29, 2008 2:04 pm
I'm not 100% sure, but I think just about any Series II will fit. The junk yards should be able to tell you that, too.
PostPosted: Sat Nov 29, 2008 2:05 pm
ok cool thanx
PostPosted: Sat Nov 29, 2008 2:23 pm
Year and Trim: 99 SSEi
Andrew is parting out a 2000 SSEi. See if he still has it. Also consider getting the coils & module. Nice to have a spare around.
http://www.pontiacbonnevilleclub.com/forum/viewtopic.php?f=27&t=4367
GM Parts Direct sells the mounting plate.
It's listed under Electrical>Ignition System>Coil Module
They show different ones for supercharged & N/A.
http://www.gmpartsdirect.com/
2006 Chevy Monte Carlo SS
Last edited by Mechanical Mike on Sat Nov 29, 2008 2:24 pm, edited 1 time in total.
PostPosted: Sat Nov 29, 2008 2:30 pm
i looked they only have the entire module that i could find i only need the plate i want to change my coils my car is acting weird but i need the plate first
PostPosted: Sat Nov 29, 2008 2:51 pm
It's there.
Ignition System is shown twice, click on the top one then after you click on Coil Module you'll see Mount bracket listed on the menu under Coil module.
PostPosted: Sat Nov 29, 2008 3:03 pm
ok found it wow its cheap 14.98 awesome thanx
There are no new unread posts for this topic. transmission mounting bracket question
tzook2009
Thu Oct 20, 2011 9:41 pm
There are no new unread posts for this topic. Mounting clips for rear applique
ddchar
Sun Aug 14, 2011 10:27 pm
There are no new unread posts for this topic. Flex-Plate Issue?????
SSEIYA
22
2784
Sun Nov 13, 2011 10:28 pm
There are no new unread posts for this topic. LICENSE PLATE LIGHT OUT
XXXPOSED501
Sat Oct 11, 2008 10:26 pm
Archon View the latest post
There are no new unread posts for this topic. Flex Plate replacement.
Sacaledus
Thu May 09, 2013 2:48 pm
Sacaledus View the latest post
Users browsing this forum: Google [Bot] and 12 guests
