It is currently Mon May 20, 2019 12:54 am
 Post subject: Shifting problem.
PostPosted: Tue Nov 11, 2008 10:55 pm
Year and Trim: 2000
Hello,
I have a 2000 Bonneville with a shifting problem. When the car is cold it seems
to shift properly. After it has warmed up it starts to shift hard on every shift. It
usually starts at around 50 mph. It will shift/jerk hard until the car is shut off for
10-15 seconds. I had an estimate for a $2300 repair bill. Any ideas would be
greatly appreciated. Thanks
 Post subject: Re: Shifting problem.
PostPosted: Tue Nov 11, 2008 11:12 pm
Year and Trim: 2003 SSEi.
LOTS of Mods
are there any Transaxle codes present??
PostPosted: Wed Nov 12, 2008 8:35 am
Year and Trim: 2000
I don't know. There are no lights that come on when this happens. I'm
thinking I'm going to have to take it to the dealer to check out.
PostPosted: Wed Nov 12, 2008 8:39 am
Before taking it anywhere, try adding a can of Sea Foam's Trans Tune, and see if that helps. Many have had luck with that freeing sticking solenoids. If it helps, run it for a while, then drop the transmission pan, and change the fluid and filter.
PostPosted: Wed Nov 12, 2008 2:15 pm
Year and Trim: 2001 se non supercharged
i agree i would put some cleaner in there first probly gummed up,you dont want to go spend 2300 when that is all they might do, mechanics are sneaky like that,i had a sensor for mine come on and it would not go out and it would not pass inspection i brought it to a mechanic he told me 3150 for a rebuild so i said i would come back so i brought it to another mechanic i brought the car in 5 min later he came out and said i was all set the wire for the sensor got clipped from driving on the highway probly a piece of metal or something.i could not belive i almost got robbed for a 3" peice of electrical tape.
PostPosted: Thu Nov 13, 2008 11:11 pm
I just added trans tune, then did a fluid change and filter, and added about 3/4 bottle of Lucas Trans Fix, and my tranny shifts so much better now. Worth the ~$40 bucks in the materials, and the hour or so of time to do.
PostPosted: Fri Nov 14, 2008 9:42 pm
Year and Trim: 10 Silverado
Take it to autozone and have it scanned. Mine doesn't have a SES light either and it's doing what yours is. I found I have a P1811 code.
2002 Buick Lesabre Custom L36 Titanium Blue Metallic/Medium Gray Cloth
2004 Buick Lesabre Custom L36 White/Graphite Gray Cloth
2015 SS Roof, Spare & 6M 6.2L LS3 415HP/415TQ SLIHRM/Jet Black Leather-Red Stitching
2010 Silverado LTZ Crew 4x4 6.2L L9H 417HP/403TQ NHT Black Granite Metallic/Ebony Leather
2013 Enclave Premium AWD 3.6L LLT White Diamond Tricoat/Cocoa Leather
2001 Wellcraft Martinique 2400 Merc 5.7L BIII 327hrs
1995 Bonneville SSE L36 Dark Polo Green Metallic **R.I.P. 4/28/10 236,400 miles**
There are no new unread posts for this topic. Shifting problem
rudydog
Fri Apr 03, 2015 12:45 am
There are no new unread posts for this topic. Tachometer / Shifting problem.
Xaelai
Fri Mar 25, 2011 7:41 am
Xaelai View the latest post
There are no new unread posts for this topic. hard shifting problem solved
wdudetocool
Thu Sep 05, 2013 2:34 pm
ryanovelo View the latest post
There are no new unread posts for this topic. Same hard shifting problem,but with new transmission...
kpolack
Tue Dec 06, 2011 2:04 pm
kpolack View the latest post
There are no new unread posts for this topic. Shifting issues
terrancew3
Fri Feb 07, 2014 6:32 pm
