It is currently Sat Oct 12, 2024 2:55 pm
PostPosted: Mon May 15, 2023 11:34 am
Hello,
2001 Bonneville SE.
At 112K miles I had the trans rebuilt.
I'm at 214K miles now and I feel it slipping when I'm in high gear when I want to accelerate.
Nothing from a standstill.....only in high when, for example entering freeway...cruise set and creeping up a hill etc.
I just put 3 new coils and an ignition control module in thinking it was a miss-fire.
Is there anything I can do other than a full teardown?
PostPosted: Tue May 16, 2023 6:18 am
Is it slipping or do you have erratic RPMs going up and down and bucking a little bit?
PostPosted: Tue May 16, 2023 8:35 am
I guess more like bucking.....
PostPosted: Wed May 17, 2023 8:29 am
So yes..it's bucking and the RPM's are erratic.
What are your thoughts?
Thanks
PostPosted: Wed May 17, 2023 9:24 am
99% of the time, your symptoms are ignition issues under load. I know you've replaced the coil and ICM already. Do you have a way to watch live data with a scan-tool to determine which cylinder is misfiring? It wouldn't hurt to change the plugs and wires also.
1997 Corvette | 55k | Silver Metallic | Z06 wheels | Date-night Hauler/Parts runner
2014 Town & Country Limited | Cashmere Pearl | 95k | Family Hauler
2002 Ram 1500 Quad Cab Sport | Black| 260k | Official Bonneville Hauler
PostPosted: Wed May 17, 2023 11:01 am
I would change plugs and wires as stated above. I've also had a dirty MAF cause similar situations.
PostPosted: Wed May 17, 2023 2:04 pm
Regarding dirty MAF......I assume there is a special cleaner for this.
Can I spray it on the vehicle or do I need to remove it?
Thanks
PostPosted: Wed May 17, 2023 2:18 pm
Year and Trim: 2003 SSEi
Yes, there is a special MAF cleaner and, yes, it's kinda pricey. I think it might be easier to clean with the MAF removed.
gweg_b wrote:
Resident Tightwad
Screw you, Photobucket.
PostPosted: Thu May 25, 2023 9:44 pm
You can get the MAF cleaner at any auto parts store. Remove the MAF and spray it down.
PostPosted: Tue May 30, 2023 2:28 pm
It was my plug wires!
Or my MAF...I cleaned it to.
Thanks for your help as always....
There are no new unread posts for this topic. Coolant issue on 2001 N/A Bonneville
Tannmann36
Sun Jun 18, 2023 11:14 pm
95naSTA View the latest post
There are no new unread posts for this topic. Possible Transmission issue
totaled
Fri Apr 13, 2012 7:30 pm
There are no new unread posts for this topic. Transmission Issue
300sflyer
Tue Jun 25, 2013 7:24 am
300sflyer View the latest post
There are no new unread posts for this topic. Transmission problem 2001 Bonneville
rollinzz
12
10150
Mon May 23, 2011 6:53 pm
There are no new unread posts for this topic. Transmission Issue, Not Sure What To Do Anymore
2KSexsei
Sat Sep 12, 2009 3:41 am
