It is currently Wed Sep 28, 2022 6:52 pm
PostPosted: Fri Jun 24, 2022 9:52 am
My blend door actuators for some reason are not working even after I replaced 3/4 blend doors and verified door #4 (blower actuator) works.
I replaced the one on my passenger side first, it was the easiest job I've done and my ac worked for that side. I spend 6 hours doing my other two (3 hours spent looking for tools) and when I go to turn my car on the air only goes to the defroster. The driver side vents have a very slight hot air flow coming out and the passenger side has room temp air that I can't notice coming out.
Does anyone know why my passenger side and in fact all the air would be coming out the defroster. I tried unplugging the battery for a minute and then plugging it in to try and get my HVAC to recalibrate.
PostPosted: Fri Jun 24, 2022 10:07 am
Pull the HVAC BATT fuse to recalibrate the actuators. Watch them during this process to make sure they are doing the full sweep both ways. If they aren't, pull the actuator and make sure you can move the doors by hand.
1997 Corvette Coupe | Silver Metallic | Z06 wheels | Date-night Hauler/Parts runner
2014 Town & Country Limited | Cashmere Pearl | 75k | Family Hauler
2002 Ram 1500 Quad Cab Sport | Black| 250k | Official Bonneville Hauler
PostPosted: Fri Jun 24, 2022 10:49 am
Ok thank you I will try that tonight thank you. I may have installed it wrong too since I haven't done this before.
PostPosted: Fri Jun 24, 2022 12:50 pm
Does anyone have the part number for the Mode Actuator?
PostPosted: Sat Jun 25, 2022 3:07 pm
I have a post on my account with the parts. It looks like the right part I compared them but for some reason my mode door actually isn't working now that I 'fixed' it lol. I think I just did something wrong
PostPosted: Mon Jun 27, 2022 9:26 am
Did you take off more than the mode actuator? Did you take off this piece as well?
PostPosted: Mon Jun 27, 2022 3:59 pm
yes I did and I think im regretting it. I fixed what wasn't broke and now I broke it. Is there something I need to know
PostPosted: Mon Jun 27, 2022 4:14 pm
The 3 arms and fingers need to be in EXACTLY this position before putting on that piece or the doors will not sync correctly.
PostPosted: Wed Jun 29, 2022 11:06 am
Ok wow that worked. I did a little testing and it looks like that middle right lever controls defrost and is spring loaded in some way to automatically go to defrost in case of failure of the actuator. Once you press it in the other ones work. After a miraculous rig job involving a clothes pin I was able to get that lever to stay just long enough to seat in the mode actuator. THANK YOU!!!!
PostPosted: Wed Jun 29, 2022 12:47 pm
Excellent. Anyone doing this job please take note, when replacing the mode actuator, do not remove the rotating assembly behind the actuator!
PostPosted: Wed Jun 29, 2022 6:26 pm
Year and Trim: 2003 Bonneville SLE Silver
This is an annoying GM problem!! I bought an actuator that is made in Canada and it solved my problem. THe issue is no one told me that you have to remove the actuator, hook up the wiring, have the car running, put the ac on max recirculating, watch the action of the little white dial. It should move back and forth when you switch from ac to the heat (temp inside the cabin). You have to be a little bit of a body bender. Have a knee pad for the concrete as you kneel up from the bottom up at the actuator. 99% chances it is not the door actuator mechansim, it's the actuator itself.
https://www.youtube.com/watch?v=jPCa2J0OyPQ&t=147s
This video is a good educational tutorial.
There are no new unread posts for this topic. manual Heater Blend Door Actuator install 2000 bonneville
jcweis1
Tue Nov 08, 2016 5:11 pm
Archon View the latest post
There are no new unread posts for this topic. BIG blend door actuator problems---HELP
Frazzled
Mon Aug 29, 2011 6:08 pm
There are no new unread posts for this topic. Passenger blend door actuator
marrober9
11
4629
Sat Feb 01, 2014 3:12 am
marrober9 View the latest post
There are no new unread posts for this topic. 2000 Bonneville Blend Door Actuators
dougtoth
Tue Apr 11, 2017 7:17 pm
scooberu View the latest post
There are no new unread posts for this topic. How to fix blend door actuators 2000 Pontiac bonneville
SylerF
Wed Jun 29, 2022 11:09 am
SylerF View the latest post
Users browsing this forum: Google [Bot] and 2 guests
