It is currently Tue Apr 16, 2024 1:02 am
PostPosted: Thu Nov 18, 2021 1:59 pm
Year and Trim: 2002 Pontiac Bonneville SSEi
Ever since I had the already discussed disastrous service from the GM dealer (transmission flush, radiator flush, oil change, etc...)...
My car has intermittent hard shifts (transmission?)...
It seems to start when the car has been running for awhile - whether it be idling for quite awhile in a long line at a fast food drive-thru waiting in line - or when driving it for a longer period of time...
The car will start to hard shift - but then if I turn it off for about 10 seconds and then turn it back on - it runs fine...
Any ideas...?
Thanks!
2002 SSEi
PostPosted: Thu Nov 18, 2021 2:41 pm
You have a P1811 code.
From: 2000+ Common Problems & Solutions (updated 5.11.11)
Quote:
    Transmission shift harsh/firm when warm
      Problem: The transmission shifts harsh after driving for a while when tranny is warm.
      Solution: The PCS (pressure control solenoid) is acting up. You might have the code P1811. While the sensor is cheap, it is located inside the transmission and the side cover must be removed to access it. To remove the side cover, the subframe must be lowered to clear the frame rail. It is a very labor intensive fix.
      It has also been said that an aftermarket shift kit can help cure this problem.
      More info: https://tripleedgeperformance.com/harsh ... -dtc-p1811
      Estimated Cost: $40 for the new solenoid, but $400-1000 in labor.
I've installed the shift kit in dozens of these cars to eliminate the problem. Never had a come-back. $50 for the kit plus new fluid & filter and a couple hours in your driveway.
1997 Corvette | 55k | Silver Metallic | Z06 wheels | Date-night Hauler/Parts runner
2014 Town & Country Limited | Cashmere Pearl | 95k | Family Hauler
2002 Ram 1500 Quad Cab Sport | Black| 260k | Official Bonneville Hauler
PostPosted: Fri Nov 19, 2021 4:39 pm
Thank you VERY much!
I noticed there are a few YouTube videos that show how to install it... one specifically for a 3800...
Is there a reason it just started literally after the dealer did the transmission flush (but didn't put in a new filter or seal as they stated they are good for a lifetime...)... ?
2002 SSEi
PostPosted: Sat Nov 20, 2021 11:47 am
In my opinion, flushes are never a good idea. But probably just a coincidence.
PostPosted: Sat Nov 20, 2021 2:51 pm
Yeah... I know, I told them I wanted a drain and fill and not a flush - but they did a flush anyway...
2002 SSEi
PostPosted: Sun Nov 21, 2021 5:41 pm
2005SLE PEARL
1975 MONTE CARLO
I agree with Andrew.
My garage where I take my car threw out their machine.
He told me there were too many problems after the flush.
What happens sometimes is that it stirs up all the dirt and particles.
As a result the dirt and particles can block up the passages where the fluid
normally flows in the transmission.
The best way is to drop the pan and change the filter and add the 4 quarts of new fluid.
If you want to you can drop the pan and change the filter and add 4 more quarts of fluid again after a short period.
The reason some shops still flush is because it is fast and is a money maker.
PostPosted: Thu Nov 25, 2021 9:52 am
Installed my kit around 70k miles and now at 227k. Haven't had any hard shifting since.
It's a pretty easy job but can be a little messy.
"Penelope" - 2003 SLE - 247k Miles
"Sydney" - 2000 Honda S2000 - 98k miles
PostPosted: Thu Dec 02, 2021 12:48 am
So you have had no transmission problems at all - other than the hard shifting that this kit took care of...?
2002 SSEi
There are no new unread posts for this topic. Transmission hard shift
Oldman
Thu Dec 01, 2011 9:10 pm
Oldman View the latest post
There are no new unread posts for this topic. transmission hard shift
mr.haney
Wed Jul 09, 2014 11:50 pm
There are no new unread posts for this topic. 2 more possibilities for transmission hard shift
torero500
Wed Nov 05, 2014 9:18 am
There are no new unread posts for this topic. Transmission Hard Shift when warmed up
Bonneville since 1984
Sun Dec 09, 2012 9:39 am
Bing View the latest post
There are no new unread posts for this topic. Hard to Turn - But only going right
Typanis
Tue Jan 03, 2012 1:29 pm
smittyingr View the latest post
