It is currently Fri Jan 21, 2022 7:45 am
PostPosted: Thu Oct 28, 2021 10:53 am
Year and Trim: 2000 SSEi 108,000 mi.
Hi all!
I recently added a 2000 Bonneville SSEi to the fleet, and it has a flaky fuel level sensor that I'm trying to replace. Managed to get the lock ring & everything loose, but the cup at the very bottom of the fuel pump seems to be a slightly larger diameter than the tank opening. No matter how I try to orient the pump, I can't get it to fit through the opening.
Am I missing something here?
PostPosted: Thu Oct 28, 2021 3:30 pm
I had this exact issue twice since I had to replace my fuel level sensor twice lol...
I use a small screw driver to pry against the fuel pump cup and force it out of the hole. It wasn't a dignified experience and it had me sweating into the fuel tank but I managed to get it out.
"Penelope" - 2003 SLE - 228k Miles
"Sydney" - 2000 Honda S2000 - 89k miles
PostPosted: Sun Oct 31, 2021 12:28 pm
Thanks Carl. Now to wait until it warms up a bit so I can work on it again. Hopefully I can get it fixed before the snow starts flying.
PostPosted: Tue Nov 02, 2021 9:06 am
I've removed dozens (maybe hundreds) of these dang fuel pumps, every single one is larger than the opening in the tank. You really have to force it. I usually find the spot it opens the most and then twist from there (kind of how you take a tire off a wheel). Even with the force, I've never broke one. Your results may vary. :P
-Andrew-
There are no new unread posts for this topic. Bonneville 3.8L and N* use same fuel pump, 3.8 SC fuel pump
MikeKerr
11
2506
Wed Mar 23, 2016 1:37 pm
Goostoff View the latest post
There are no new unread posts for this topic. door to fuel tank
pete25
Sun Aug 03, 2008 4:57 pm
Rusgreim View the latest post
There are no new unread posts for this topic. Fuel leak when tank is filled
dz09x
Wed Sep 26, 2012 11:51 pm
Archon View the latest post
There are no new unread posts for this topic. Fuel Tank leak--- '00 Lesabre
dandyd
Fri Oct 14, 2011 1:28 pm
dandyd View the latest post
There are no new unread posts for this topic. Growling from the fuel tank at start-up
Ken_W
Thu Feb 23, 2012 9:36 pm
Ken_W View the latest post
