It is currently Tue Aug 11, 2020 9:26 pm
 Post subject: Ignition issue
PostPosted: Thu Jul 02, 2020 5:46 pm
1992 Bonneville SSEi (Sold)
Hi all
Is or has anyone used the zzp high voltage coils and 10.5mm wires? I'm asking cause I'm currently using them with ngk laser iridium itr6f13. Since install I'm having a " big down" randomly through all rpms even at idle. Ran it with the plugs gapped at the .052 then gapped them to the .060 the car calls for with no change. Checked the firing order a million times. Has anyone run into this before? Or maybe the wires/coils are to much?
2001 SSEi Bumbles
 Post subject: Re: Ignition issue
PostPosted: Fri Jul 03, 2020 8:27 am
Do you have stock items to swap on as a test?
"Penelope" - 2003 SLE - 210k Miles
"Sydney" - 2000 Honda S2000 - 76k miles
PostPosted: Sat Jul 04, 2020 10:26 am
Year and Trim: 2003 SSEi
Based on my experience with those exact products, one of your coil packs is shot. I had mine on for less than a year before one of them went south on me. Very disappointing.
Swap out with a stock one until you isolate which one so you can verify the cause. Then throw away the zzp coil packs and replace them with stock. Lol.
Their wires hold up just fine, no issues, but check to make sure they haven't been touching anything too hot and gotten burnt through.
PostPosted: Mon Jul 06, 2020 10:56 pm
I don't have any other stock parts left. Coils were cracked. I put in a brand new ICM and it made it worse to the point could barely go up a hill. I swapped my old one back in. Checked everything all over again. I'm gonna swing by NAPA and see if they will warranty my old wires. Also I have only been using the zzp plugs and wires for maybe about 2 weeks now has been happening since day one.
2001 SSEi Bumbles
PostPosted: Tue Jul 07, 2020 11:43 am
2005SLE WHITE
1975 MONTE CARLO
Is there a junk yard near you where you can take off the whole ICM assembly with the coils on it?
Any 3800 starting with the year 2000 and up should work.
If not contact Andrew at Bonnevilles Unlimited (507) 220-2000 and he should be able to help you.
PostPosted: Tue Jul 07, 2020 6:09 pm
you should pull the code and maybe it will pinpoint the cylinder# - then you trace to coil....wire, plug
the cheap oem coils are about 30 bucks. get one for spare /diagnosis if needed
PostPosted: Tue Jul 07, 2020 9:15 pm
I did try that but no luck. No codes no misfires. Drove it with the tech 2 trying to isolate what cylinder but all day looked good. Gonna need to drive with a co pilot to verify.
2001 SSEi Bumbles
PostPosted: Wed Jul 08, 2020 9:48 am
2005SLE WHITE
1975 MONTE CARLO
For what it is worth the last time my ICM went bad the SES light never came on and it did not throw a code.
I really think you have an ICM issue.
The new ICM'S are all Chinese garbage.
Try and get an OEM one from a junkyard or from Andrew.
There are no new unread posts for this topic. Trans Issue or Ignition/Fueling Issue(s)
WhiteArrow3800
15
2010
Wed Aug 26, 2009 11:11 pm
There are no new unread posts for this topic. ignition issue's
Adamus Prime
Thu Jun 21, 2012 1:33 pm
Adamus Prime View the latest post
There are no new unread posts for this topic. Ignition HELP!!!
EMTprincess33
Thu Jun 19, 2014 2:00 pm
EMTprincess33 View the latest post
There are no new unread posts for this topic. Key stuck in ignition!!!
Mrs. Sisk
Mon Dec 29, 2014 1:22 pm
38bonne View the latest post
There are no new unread posts for this topic. best ignition module
irv
Sun Aug 30, 2015 8:34 am
irv View the latest post
