It is currently Wed Dec 02, 2020 3:12 pm
PostPosted: Wed Apr 15, 2020 7:45 pm
so I had my car on the lift the other day and noticed the passenger side shock is leaking oil out of it and needs replaced. I know they are air shocks and my compressor is in good working order. below are the options I am finding. I am pretty sure #2 is the factory replacement for them and I am fine with ordering those, but is there any improvement to be had by a different brand (not interested in switching to non-air ride shocks.)
https://drive.google.com/open?id=12-uA8 ... 4qaisbqsFR
3.8L V6 SC, 180*T (Drilled),
Custom PCM w/Perf Shift,
SLP Ceramic Coated Headers,
Thrasher Cold Air Intake,
PostPosted: Wed Apr 15, 2020 11:55 pm
2005SLE WHITE
1975 MONTE CARLO
I have used the Monroe MA822 on my Bonnevilles.
Them seem to work fine and the fittings from the air lines match up.
Just make sure the shock mounts are also good.
PostPosted: Thu Apr 16, 2020 9:46 am
Year and Trim: 2003 SSEi
I put Monroes on my 2003 and had a clunk at full extension from one of them. Wasn't damped for the full stroke. I swapped them out for KYBs. Been happy with them. There is a shock thread on 2000+ shocks somewhere, lots of opinions in that one.
gweg_b wrote:
Resident Tightwad
Screw you, Photobucket.
PostPosted: Thu Apr 16, 2020 10:03 am
2005SLE WHITE
1975 MONTE CARLO
Possible that the shock was defective.(wouldn't be the first time that new parts are bad)
I have used the Monroe's on 5 different Bonnevilles and have had no problems.
KYB is a good brand but again I have had no problems with the Monroe's.
The weird thing is that the shock mounts are almost more expensive then the shocks.
PostPosted: Thu Apr 16, 2020 10:47 am
Yes, the shock was defective. But by the time it manifested itself it was too late to do anything about it. The only time it was noticeable was in a hard right turn that would pull the RR shock to it's limit quickly (like when I'm trying to beat that other dude into the Lowe's parking lot). Any other time it was fine. I wanted to try the KYB so I replaced the rears with those. I think the quality is a little better, but that is just a perception as all shocks probably come out of the same child labor camp in China.
Resident Tightwad
PostPosted: Fri Apr 17, 2020 10:03 am
After going through various air shocks over the years, Monroes, KYBs, ACdelcos and Gabriels, they all seemed to stop working and sealing properly after a while.
Finally at 185k miles I switched over to spring loaded Monroe non-air ride in the rear and never looked back. Ride is identical.
"Penelope" - 2003 SLE - 212k Miles
"Sydney" - 2000 Honda S2000 - 78k miles
PostPosted: Fri Apr 17, 2020 8:22 pm
Thank's Y'all, I was a fan of the ride with KYB's all the way around on my last vehicle...think I may go that route on this one as well.
PostPosted: Sat May 09, 2020 1:02 am
Well I went with:
KYB SR1002 Shocks
Moog K5341 Shock mounts
Moog 80659 springs.
Energy Suspension 9.5124R 20MM SWAY BAR BUSHING SET -- ***DOES NOT FIT/DO NOT ORDER***
Energy Suspension 9.8120R END LINK SET
All the parts finally came in...will be doing the upgrades tomorrow if all goes well.
PostPosted: Sat May 09, 2020 3:19 pm
Got everything installed (except the poly sway bar bushings...right internal diameter but mount is completely wrong and the outer diameter is too small to reuse the factory mounts.) car sits level again, rides smooth and corners way better than the old warn out rubber end links let it. Very Happy.
There are no new unread posts for this topic. Rear Shocks I think
00bonne
Tue May 13, 2014 3:32 pm
There are no new unread posts for this topic. Rear Shocks?
billberry12
17
8874
Sat Oct 09, 2010 12:33 pm
There are no new unread posts for this topic. rear shocks
chelbanger
Thu Jan 19, 2012 11:41 am
chelbanger View the latest post
There are no new unread posts for this topic. Rear shocks
shawnyoung
11
2974
Mon Sep 20, 2010 8:45 pm
carl View the latest post
blackjack
Thu Dec 31, 2015 8:44 pm
MKMike View the latest post
