It is currently Wed Apr 08, 2020 2:07 am
PostPosted: Thu Feb 20, 2020 4:28 pm
First noticed the problem going through a roundabout yesterday, turning left through it I heard a grinding/squealing coming from the front drivers side. It sounds like metal on metal as if my brake pads were bad but I replaced front pads/rotors/bearings less than 500 miles ago. Upon quick inspection I noticed that the drivers side rotor is quite rough on the outside face while the inner face is smooth. The pass rotor is smooth too. I’m thinking it might be something caught in between the pad and rotor. Any other ideas? I can’t get it into the garage right now but any input would be appreciated.
PostPosted: Fri Feb 21, 2020 12:13 pm
welcome to the club!
I would check the brake job you just did - did you clean the sliders so the caliper moves freely? sounds like its binding causing uneven wear. when you get it apart, you will see the issue. one pad will be thick and the other, almost down to the rivets.
take it easy on the brakes until you sort this.
PostPosted: Fri Feb 21, 2020 9:58 pm
Doesn't grind while braking in a straight line?
Sounds like you just need to get it up in the air again and see what's going on in there.
"Penelope" - 2003 SLE - 203k Miles
"Sydney" - 2000 Honda S2000 - 71k miles
There are no new unread posts for this topic. Thud noise and cracking noise when turning the wheel
llllcdllll
Thu Jun 30, 2011 2:37 pm
llllcdllll View the latest post
There are no new unread posts for this topic. Abs comes on randomly when turning left or right WTF?
BRUTE FORCE
16
1413
Fri Jun 06, 2014 4:00 pm
02 bonnie beast View the latest post
There are no new unread posts for this topic. Grinding Noise After Starting
jmusser218
Wed May 28, 2014 11:12 am
jmusser218 View the latest post
There are no new unread posts for this topic. Ringing noise when turning
Terra
Fri Nov 04, 2016 3:45 pm
96 SSEi View the latest post
There are no new unread posts for this topic. Awful noise when turning.
BassinmyBlood
Fri Sep 07, 2012 8:51 pm
dz09x View the latest post
