It is currently Fri Apr 10, 2020 7:57 am
PostPosted: Sun Feb 16, 2020 12:01 am
Year and Trim: 2000 pontiac bonneville SSEi
The heat on my ride only blows out the defroster. I found where the vacuum line for the HVAC starts; it's plugged off. Does anybody know where the hose leads to? I have the automatic HVAC.
PostPosted: Sun Feb 16, 2020 11:11 am
The 2000+ HVAC system is electronic. Check out the 2000-2005 section, specifically the common problems thread. There are photos there of the position of the actuators which move the air.
"Penelope" - 2003 SLE - 203k Miles
"Sydney" - 2000 Honda S2000 - 71k miles
PostPosted: Tue Mar 31, 2020 8:24 pm
also there is a re-sync procedure you can try...sometimes the actuators get out of sync.
From GMSI:
Calibration Procedure (without a Scan Tool)
1. Turn OFF the ignition.
2. Remove the battery positive voltage circuit fuse for the Instrument Panel Control Module.
IMPORTANT:
The module memory will not clear if the battery positive voltage circuit fuse is installed in less than 60 seconds.
3. Wait 60 seconds.
4. (re)Install the fuse.
3.8L V6 SC, 180*T (Drilled),
SLP Ceramic Coated Headers,
Thrasher Cold Air Intake,
There are no new unread posts for this topic. seafoam through vacuum line 2000 SSEI
LAIDBACKLUKE
Sat Apr 16, 2011 11:29 pm
There are no new unread posts for this topic. vacuum hose location
bonnieandclyde
Tue Aug 21, 2012 12:53 am
nickburgundy View the latest post
There are no new unread posts for this topic. HVAC Control Assembly question 2000-2005
Wayne Adam
Tue Nov 28, 2017 3:20 pm
Wayne Adam View the latest post
There are no new unread posts for this topic. 2000 SE EGR outlet line vacuum leak
Merrillspontiac
Wed Apr 12, 2017 2:36 pm
96 SSEi View the latest post
There are no new unread posts for this topic. 2000 bonneville radiator low coolant sensor location???
shipmanlights
Thu Jul 29, 2010 10:55 pm
shipmanlights View the latest post
Users browsing this forum: xcbullet and 12 guests
