It is currently Sun Mar 29, 2020 7:24 pm
 Post subject: wont go over 45 mph
PostPosted: Mon Dec 30, 2019 6:32 pm
Year and Trim: 2002 pontiac bonneville sle
ok i have a problem i cant figure out. 2002 sle has intermittent problem where the car won't go over 45 mph and on occasion it wont go over 10 mph. it does surge when idling. i have fixed and replaced.
couple vacuum leaks and sprayed intake with carb cleaner.
check fuel pressure 44 pounds and pulled off vacuum went to 54 pounds
replaced mass air flow
replaced cps
codes are o2 sensor bank one
 Post subject: Re: wont go over 45 mph
PostPosted: Tue Dec 31, 2019 9:03 am
Year and Trim: 01 SSEI (black)
00 SSEI (green)
You need a scan tool to see what your upstream o2 sensor is doing. If it's reading an incorrect voltage, then your fuel mixture will be too lean or too rich. The vehicle will run poorly if the upstream o2 is malfunctioning.
PostPosted: Fri Jan 03, 2020 9:47 am
Any codes?
"Penelope" - 2003 SLE - 203k Miles
"Sydney" - 2000 Honda S2000 - 71k miles
PostPosted: Mon Jan 06, 2020 8:18 pm
I forgot i had changed both 02 sensors about a month ago. i have a spare bonneville for parts i pulled the 02 sensor off of it and problem went away. i guess the new 02 sensor was bad. my scanner is a piece of crap so i found a mac mentor scout at the pawn shop for cheap.
PostPosted: Thu Jan 30, 2020 10:00 pm
Year and Trim: 2002 se
What are the brands of parts you are using?
Here is a list of recommended brands. 1992/topic16991.html
There are no new unread posts for this topic. Low Beams wont come on???
3800Charged
Tue Mar 20, 2012 4:44 am
Winn View the latest post
There are no new unread posts for this topic. P0420 wont go away!
jddem
Wed Aug 22, 2018 7:28 am
jddem View the latest post
There are no new unread posts for this topic. My key wont come out of the ignition
Leftd90
Sat Jun 28, 2008 3:20 pm
Leftd90 View the latest post
There are no new unread posts for this topic. CAR WONT START!!!
lilwilli3
Sat Apr 23, 2011 2:28 pm
There are no new unread posts for this topic. passenger window wont go down
mdrew
Thu Nov 29, 2012 11:50 pm
Archon View the latest post
