It is currently Wed Jan 22, 2020 4:00 am
PostPosted: Mon Dec 02, 2019 8:51 pm
Year and Trim: 01 Bonneville SSEi
It is above the passenger side cv axle and below the power steering reservoir. I can't find the source.
2001 SSEi.
 Post subject: Re: Guess this leak...
PostPosted: Mon Dec 02, 2019 11:34 pm
I would suggest power steering hose or axle seal. There's not much else back there.
07 Infiniti G35s 6MT
05 Suzuki DRZ400S
PostPosted: Tue Dec 10, 2019 10:09 pm
I checked the hose coming out of the power steering reservoir. It is wet, but not dripping wet like this other part...
PS
Some sort of sensor that is super wet/leaking:
PostPosted: Tue Dec 10, 2019 11:09 pm
Probably the oil pressure sender, which is a known painpoint in these cars.
PostPosted: Wed Dec 11, 2019 12:40 am
That's what I am thinking it is. Is this a simple remove old sensor and replace with new sensor deal?
The part seems cheap enough to DIY: https://www.partsgeek.com/1plxb66-ponti ... ender.html
PostPosted: Wed Dec 11, 2019 9:09 am
Year and Trim: 01 SSEI (black)
00 SSEI (green)
Very easy to do.
Would suggest doing along with an oil change. If you remove the sensor prior to draining oil, it will lose oil thru that port. Not a big deal but easier to do with the oil drained regardless.
PostPosted: Wed Dec 11, 2019 11:30 am
Very easy swap and you can get these parts at any local store.
Doing it with an oil change is recommend as without the oil filter, the access is a little easier.
"Penelope" - 2003 SLE - 201k Miles
"Sydney" - 2000 Honda S2000 - 70k miles
PostPosted: Wed Dec 11, 2019 11:48 am
2005SLE WHITE
1975 MONTE CARLO
Like stated above a pretty easy job with the oil filter off.
I bought a 27mm deep socket which made the job a lot easier.
Usually that sending unit goes bad and the oil pressure gauge reads all over.
PostPosted: Wed Dec 11, 2019 3:35 pm
Yeah, that's another good point. The socket size is huge at 27mm. Lol I was able to use an adjustable wrench the now 2 times I've had to replace mine.
PostPosted: Wed Dec 11, 2019 4:49 pm
27mm? Sounds like a good excuse to buy a new socket...https://smile.amazon.com/ARES-Retention ... B073WJ47R1
Also, should I go Duralast (cheaper & lifetime warranty) https://www.autozone.com/external-engin ... 862_0_1489
Or ACDelco (1yr warranty,but maybe better quality?) https://www.autozone.com/external-engin ... 7/936094_0
PostPosted: Wed Dec 11, 2019 5:42 pm
2005SLE WHITE
1975 MONTE CARLO
I went with the Duralast.
It has a lifetime warranty.
I have already got 3 of them at N/C which I use on all my Bonnevilles.
PostPosted: Wed Dec 11, 2019 9:49 pm
Girlfriend's LeSabre had the pegged oil pressure gauge problem. Then one day it started using oil. When I changed the oil, I changed the pressure sender (it's right above the oil filter). It was pretty slimy so I suspect it was leaking. Engine hasn't used any oil since.
It was a bit of a pain, but I used an adjustable wrench. Took maybe 20 minutes to get it out due to limited area for wrench movement. I used the BWD brand sender from Advance Auto. It's been in since May and so far so good.
PostPosted: Wed Dec 18, 2019 3:59 pm
Year and Trim: 2000 SLE; Arctic White, camel
interior; moonroof
I replaced the oil pressure sending unit on my 2000 SLE about 1,000 miles ago, and since then have not had to add a drop of oil. I had been going through a quart about every 800 miles from a slow leak some place or other or burning oil. But it now seems it was just leaking at that oil pressure switch. I bought the AC Delco one and a $6 socket to fit it from Amazon.
Cars so far:
1957 Volkswagon Beetle
1957 Triumph TR-3
1964 Rambler
1966 Corvair Monza
1963 Volvo 122-S
1971 Chevrolet Malibu (350)
1979 Pontiac Formula Firebird (301)
1974 Pontiac Trans-Am (455)
1975 Mercedes 250 SE
1989 Toyota Supra Turbo
1979 Mercury Colony Park Station Wagon
1995 Corvette
1996 Chevrolet Impala SS
1989 GMC Ventura Conversion Van
2000 Pontiac Bonneville SLE (now with a new $2,021 Transmission)
1994 Jeep Grand Cherokee Laredo
2003 Lincoln Town Car, Cartier
There are no new unread posts for this topic. Oil Pressure Sending Switch
mshipon
Mon Jan 03, 2011 10:02 pm
There are no new unread posts for this topic. Oil pressure sensor
luke_dubs
Fri Jan 18, 2019 5:04 pm
luke_dubs View the latest post
There are no new unread posts for this topic. 01 SSEi fuel pressure leak down
Oldman
Fri Jan 17, 2014 6:32 pm
J Wikoff View the latest post
There are no new unread posts for this topic. oil pressure sensor question
Franksdad
Thu Dec 12, 2013 3:06 pm
Franksdad View the latest post
There are no new unread posts for this topic. Oil Pressure Sensor is pegged
mrwildroot
18
2871
Sun Jul 21, 2013 5:00 am
mrwildroot View the latest post
Users browsing this forum: Google [Bot] and 5 guests
cron
