It is currently Fri Aug 14, 2020 10:31 am
 Post subject: 2000 running issues
PostPosted: Sun Aug 18, 2019 6:28 pm
Year and Trim: 2000 SE
I have a standard 3.8 and having issues with it stumbling and not running right.
I can get it to start if I give it gas and pump a little, I had taken it to a shop and had a scan of MAS. I replaced it with a new one but no change. I know that I should be able to unhook the MAS and it should run but it doesn't, it will run given gas and started and the promptly die.
After that I plugged the MAS back in and it idled well but stumbled and sputtered under rev or under load. Previously/ at times it would buck, backfire and throw a total fit while I would try to get it started and stay running while on and off the gas pedal.
Ideas?
 Post subject: Re: 2000 running issues
PostPosted: Sun Aug 18, 2019 10:09 pm
If you have never replaced it yet, replace the fuel pressure regulator with an ACDelco one. I would start there.
"Penelope" - 2003 SLE - 210k Miles
"Sydney" - 2000 Honda S2000 - 76k miles
There are no new unread posts for this topic. idle and running issues for the 03 *still having issues*
crash93ssei
11
2261
Sun Dec 04, 2011 3:28 pm
There are no new unread posts for this topic. Numerous running issues!
spacelucky17
Sat Apr 27, 2013 2:07 pm
spacelucky17 View the latest post
There are no new unread posts for this topic. SSEi running issues
bnuge942
17
2838
Wed Feb 08, 2012 3:17 pm
bnuge942 View the latest post
There are no new unread posts for this topic. Starting/running issues (battery replaced)
garlandchaos
Fri May 21, 2010 6:17 pm
In_da_boondocks View the latest post
There are no new unread posts for this topic. 2000 Bonneville running rough
ThatThar
11
1743
Sun May 10, 2015 1:04 pm
ThatThar View the latest post
