It is currently Wed Dec 02, 2020 2:46 pm
 Post subject: 2005 SLE Question
PostPosted: Sun Jul 21, 2019 5:57 pm
2005SLE WHITE
1975 MONTE CARLO
Sometimes when I shut off the car and take the keys and open the drivers door the radio does not shut off.
It does not do this all the time.
I then close the door and reopen it and it goes off.
I also noticed that the car does not honk when I hit the key fob to lock it but is does lock.
Is there a switch on the door that is hanging up or a module that controls this?
Thanks.
 Post subject: Re: 2005 SLE Question
PostPosted: Sun Jul 21, 2019 10:47 pm
There is a switch in the door latch assembly. When you open the door (without going into the long detailed explanation), it signals the car to turn off the radio. You can check the wiring in the door, but my guess is that you'll be replacing the latch. The switch is not considered to be serviceable since that would require disassembly of the latch mechanism. This problem has been reported several times.
As for the horn, you should be able to change its behaviour through personalization settings. With an SLE, you should have the DIC and settings can be changed there. I have mine disabled because I'm sure the neighbours don't appreciate hearing the horn when I get home in the middle of the night.
PostPosted: Mon Jul 22, 2019 9:07 am
2005SLE WHITE
1975 MONTE CARLO
Thank you!!!
I will look into it.
There are no new unread posts for this topic. 2005 Replacement Strut question
Wayne Adam
Mon Jul 20, 2015 4:01 pm
There are no new unread posts for this topic. 2005 SE 4T65E question/suggestions?
1oldman
Wed Nov 09, 2016 8:12 am
There are no new unread posts for this topic. 2005 SE - Auto-lock question
jtmontano
Mon Sep 29, 2014 10:23 am
There are no new unread posts for this topic. HVAC Control Assembly question 2000-2005
Wayne Adam
Tue Nov 28, 2017 3:20 pm
Wayne Adam View the latest post
There are no new unread posts for this topic. Re: question for you pls. Cabin air filter question.
sonoma_zr2
Tue Aug 16, 2011 10:31 pm
Users browsing this forum: No registered users and 17 guests
