It is currently Wed Jun 03, 2020 6:51 am
PostPosted: Mon Jul 15, 2019 2:32 pm
Year and Trim: 2002 SE, 2013 Regal GS
So, it seems to be about time to take a look at the front valve cover gasket (as a couple of times over the last few days, after driving home, I smelled a candle-like smell, and saw smoke/steam coming from a spot on the exhaust manifold). Does anyone know a good place to get a replacement gasket that doesn't seem too cheap?
Thanks.
'13 Buick Regal GS 68k miles, 270 hp, 295 lb/ft of torque.
PostPosted: Mon Jul 15, 2019 2:38 pm
you may want to shop around your area and compare price/quality: Felpro is a reputable brand.
PostPosted: Mon Jul 15, 2019 2:57 pm
2005SLE WHITE
1975 MONTE CARLO
I used Felpro on mine.
No problems.
Also replace the grommets while you are at it.
PostPosted: Tue Jul 16, 2019 11:11 pm
I used Felpro as well, as said above, make sure you get the grommets too.
Front cover is a 15 minute replacement.
PostPosted: Wed Jul 17, 2019 4:51 pm
Thanks guys, I appreciate it.
PostPosted: Wed Jul 17, 2019 10:00 pm
May want to do both while you're at it. If the front one is leaking, the rear probably is too. The front gasket is easy and will take less than a half hour. The rear gasket is another story. Took me about and hour.
Felpro is good. When I did the back one I had to use a few dabs if RTV to hold the gasket in place while I put the cover on, otherwise it falls off the cover.
Not sure why the NA and SC engines use different gaskets.
There are no new unread posts for this topic. valve cover gaskets......
SLEking
Wed Apr 13, 2011 1:34 pm
There are no new unread posts for this topic. Valve Cover Gaskets A No Go
Jaxstarke99
Fri Jun 16, 2017 8:47 am
There are no new unread posts for this topic. Valve cover gaskets
Silver Bullet
Sun Apr 29, 2012 8:06 pm
Grimm View the latest post
terrancew3
Sat Dec 22, 2012 9:59 pm
There are no new unread posts for this topic. L36 valve cover gaskets: recommendation?
Bugsi
Thu Aug 12, 2010 11:28 pm
1fatcat View the latest post
