It is currently Mon Dec 09, 2019 8:11 pm
PostPosted: Sat Jun 29, 2019 6:12 am
Recently noticed a coolant puddle under the front of my girlfriend's '02 LeSabre. Car would pull water out of recovery tank, but pushes water out on ground. Temp is normal in the 195-220 range. Needle barely goes a tick over half way, so it's not overheating. The top of the radiator near the cap was wet so I started with the cheapest fix if a new radiator cap but it would still push water out.
Since it only loses coolant when hot and parked, i drove it around a bit and looked under the hood. Heard slight hissing and water started streaming (like from a pinhole) from the radiator... passenger side, right next to the cap, right where the tank is crimped onto the core.
Is there some way to fix this without pulling it all apart (I hate using leaks stopper because it usually gunk's everything else up)? Or is it best just to pull the radiator and replace it? It looks like it's a simple enough job. Tranny cooler lines, radiator hoses, and two mounting brackets on top and it should slip out.
Since it's not overheating, I'm just making sure to keep water in it but know it's gonna need to be fixed soon.
PostPosted: Wed Jul 03, 2019 3:08 pm
In my opinion, I would just replace it. I've never known repairs to this type of radiator to go well and it would quite likely end up being more of a headache in the long run. I also won't use additives to plug leaks because I just don't believe them to be a "best practice" solution.
PostPosted: Wed Jul 03, 2019 10:18 pm
Replace it, they are not expensive nor that bad of a job. Transmission cooler lines are a bit finicky, but it's not bad at all. I changed one with a bit help at 17 years of age, one month after my first brake job... haha!
"Penelope" - 2003 SLE - 200k Miles
"Sydney" - 2000 Honda S2000 - 70k miles
PostPosted: Thu Jul 04, 2019 11:43 am
Well, I bought myself some time because I ha e other issues to attend to.
I also hate using additives. Especially with all the Bars Leak Stop horror stories I've heard.
I found its Alumaseal powder stuff and it got decent reviews so I figure it was worth a try from r $3.
The leak has stopped. Four days later and the recovery tank is still full. I'll just keep an eye on it.
There are no new unread posts for this topic. Coolant Leak Radiator Cap
gold_xero
Tue Oct 11, 2016 10:33 am
gold_xero View the latest post
There are no new unread posts for this topic. 2001 Bonnie radiator leak from fitting
raa1144
Mon Apr 14, 2014 4:09 pm
There are no new unread posts for this topic. Found out my leak on the SSEi, what should I replace?
Ramcharger310
Fri Sep 19, 2014 12:51 am
Ramcharger310 View the latest post
There are no new unread posts for this topic. Attachment(s) RADIATOR?
bslayer
Tue Feb 25, 2014 11:13 pm
There are no new unread posts for this topic. replacing radiator, what else should I consider?
DOMESTICated
Tue Oct 11, 2016 5:26 pm
Users browsing this forum: No registered users and 24 guests
