It is currently Sun Aug 18, 2019 9:32 pm
PostPosted: Mon Jun 17, 2019 4:53 am
Year and Trim: 00 Bonneville SSEi
Aloha all. I’m finally continuing my 2000 SSEi rebuild after 2 years and am looking for opinions and advice as I progress in my build. I spun a rod bearing in March 2017 and so far I have:
- had the block cleaned and inspected for cracks, should be ok to reuse
- crankshaft inspected and polished
- con rods will be inspected this week, at least 5 are ok(I do have 6 extra OEM L67 rods)
- heads inspected and cleaned + valve job
For parts, Ive ordered
- ZZP Master Gasket Set w/ FelPro head gaskets
- Valve Stem Seals
- Balance Shaft Bearings - std
- Camshaft Bearings - std
- Connecting Rod Bearings - .001” undersized
- Main Bearings - std
I’m also thinking about getting a
- ZZP VS cam
- ZZP 5/16 7.00 pushrods
- LS6 90lb valve springs
Not looking for anything crazy, just a slightly better than stock rebuild. If I could extract 300whp I’d be happy. I have headers and an intake sitting in boxes on the side I may as well throw on too. I have a few questions before I order anything else if anyone can chip in?
- I can’t find stock replacement con rod or main cap hardware except for ARP stuff, I have no experience with any ARP. Thoughts? It’s all I can find as replacements.
- ARP makes Head Studs instead of bolts, can I still pull the heads if I have to do a future head gasket replacement?
- Is a PCM tune required to run an aftermarket cam like the VS?
Thanks in advance! Ive never done an engine rebuild before, only tear downs.
2000 Bonneville SSEi
2013 Taurus SEL - My Nurse’s car
2002 RSX-S 6spd - Daily Driver Pocket Rocket
2008 F150 Lariat - Lifted, 17x10 Fuels, 305s, Waipio
PostPosted: Fri Jun 28, 2019 3:06 pm
Some parts came in. Just waiting on the piston rings and Intense valvetrain package.
PostPosted: Fri Jun 28, 2019 10:50 pm
Hey there!
I don't think you'll get to 300 whp without an intercooler but I'd bet that set up will give you 260+ for sure.
However! You do need to get a tune, not only for the cam, but because you'll be dropping pulley sizes and adding boost.
Also, remember that the transmissions are the weak point here.
"Penelope" - 2003 SLE - 193k Miles
"Sydney" - 2000 Honda S2000 - 67k miles
PostPosted: Sat Jun 29, 2019 4:36 pm
nos4blood70 wrote:
Hey there!
That’s good news, 260. Guess Ill look into getting a ZZP intercooler a little later.
That’s what I needed to know. Wasn’t sure if the factory PCM could compensate. Figuring maybe a 3.5 pulley is conservative enough?
Any easy trans mods to do while the engine is out? I’d think a trans cooler wouldn’t be a bad idea.
 Post subject: Rebuilding The L67
PostPosted: Sat Jul 13, 2019 4:41 pm
All of the parts are in minus the Total Seal piston rings which were ordered by my builder. Will begin the build next Thursday! YEEEEEESSS
PostPosted: Tue Jul 23, 2019 1:58 pm
Year and Trim: 2000 SSEI
DANG! Nice build!
S
Shane "RedZMonte"
2004 Z16 Z06: Virgin
PostPosted: Wed Aug 07, 2019 4:50 pm
redzmonte wrote:
DANG! Nice build!
S
Can’t wait for everything to be finished! There are no other Bonneville in my area except for a black GXP, but I haven’t seen it around since it sold off Craigslist. I’ll pretty much be the only one driving around lol
PostPosted: Thu Aug 08, 2019 8:42 am
Year and Trim: 2003 SSEi
20SSEi00 wrote:
redzmonte wrote:
DANG! Nice build!
S
I think lately this is true no matter where you live. Lol. Bonnevilles are unicorns these days.
I'm very interested to see how this build goes as well! I've got the L36 on my Camaro about 1/3 torn apart at the moment, so I'm all about the engine info and builds lately.
PostPosted: Thu Aug 08, 2019 12:21 pm
hi, you have a pile of go fast stuff: dont forget about the transaxle or you may have a 300hp anchor.
PostPosted: Thu Aug 08, 2019 9:04 pm
What are your suggestions? Besides the plan to change the trans fluid with maybe a newer spec Dexron fluid, quality filter kit, an external trans cooler and knock mat kit that mounts to the trans, I haven’t made any plans to modify the transmission.
PostPosted: Fri Aug 09, 2019 1:00 pm
Year and Trim: '93 SSEi
'05 STS-4
'97 LeSabre
The big ones I can think of for the trans are the 4th hub, a shift kit, and replace the oil pump shaft if the splines are worn on either end in addition to the trans cooler. Then while you've got that open, the PCS and switch bank, just as PM. Check the diff pin that the roll pin isn't falling out and don't do burnouts.
Runs:
Doesn't run:
PostPosted: Fri Aug 09, 2019 2:33 pm
apart from the above,I would have regular fluid changes so I would install a drain plug in trans pan to make changes a breeze.
I would also install a fan on the new cooler, and a temp sender: heat and dirt are a trans #1 killer
PostPosted: Fri Aug 09, 2019 4:38 pm
No kidding. It’s so hard to find any parts for this car. Feel more like Indiana Jones searching for hidden treasure online when I’m looking for taillights lol if Bonneville are unicorns, then when I start the body work and repainting process, I may as well do the base color white and throw in a rainbow of pearls for the pearl coat! Purple spoiler and a ZZP decal on the rear quarter and all lol
Stay tuned. I will update as progress is made. I’m on vacation and will be doing other small projects I can post about on here.
You may have to translate for me, I don’t understand automatic transmissions or it’s mods. To me it’s all magic and pixie fairies in a metal box that’s better if I don’t ask any tough questions. I know a shift kit replaces the valve body and springs to improve shift points and the external trans cooler is to help keep the fluid cool to extend trans life but that’s about it. 4th hub, PCS, switch bank, diff pin and roll missed me. I do understand burnouts though if that counts? Lol Transmission has 60K at the moment.
Do you know if anyone makes a modified pan or is a drill the pan and weld a nut application? Better than dropping the pan every 20-30K miles.
Agreed.
PostPosted: Sat Aug 10, 2019 12:24 pm
yes, you can drill and install a drain plug - no need to weld if bit matches outside diameter of plug.
There are no new unread posts for this topic. hot restart problems
2003BlackSapphireSLE
Sat Apr 14, 2012 12:02 pm
There are no new unread posts for this topic. Random stalling with hard restart.
bc21
Thu Mar 21, 2013 2:38 pm
mrwildroot View the latest post
There are no new unread posts for this topic. 2002 SLE Shuts down and won't restart for several hours
cudaguy
18
1231
Tue Mar 22, 2016 11:31 am
Goostoff View the latest post
There are no new unread posts for this topic. 2002 bonneville died and wont restart
satern13
Sun Jul 07, 2013 7:48 pm
satern13 View the latest post
There are no new unread posts for this topic. LED project, need information
FIND
Sat Feb 04, 2012 5:28 am
leatherneck View the latest post
