It is currently Tue Sep 17, 2019 1:14 pm
 Post subject: Power steering hoses
PostPosted: Thu May 30, 2019 7:10 pm
Year and Trim: 2002 se
Looking to replace the power steering hoses on my 2002 se. what kind of job am I looking at? anybody that has done this job any insight would be great....thanks
 Post subject: Re: Power steering hoses
PostPosted: Thu May 30, 2019 8:37 pm
Year and Trim: 2005SLE Crimson
2005SLE White
1975 Monte Carlo
Not that bad of a job.
Make sure you use tubing or flare nut wrenches.
If you don't you more than likely round off the nuts.
After you are done turn the steering wheel back and forth to get any air out.
Figure a couple of hours.
PostPosted: Fri May 31, 2019 9:57 am
16mm on the pump side, 18mm on the rack side. Sometimes its just easier to cut the line right by the nut and use a standard socket to get it off. If its been leaking for a while, its going to be a messy job.
-Andrew-
PostPosted: Fri May 31, 2019 3:36 pm
thanks guys got some time next week got the hoses in just getting everything lined up....i was thinking i had to remove a bunch of stuff to get them out....much appreciated
PostPosted: Fri May 31, 2019 4:17 pm
Only replace the high pressure line unless you know for a fact that the return line is leaking (very rare).
-Andrew-
PostPosted: Sat Jun 01, 2019 7:43 pm
Girlfriend's '02 LeSabre has a P/S hose leak. I'm assuming it's the high pressure hose. I have to refill the reservoir once every two weeks so it's not hemmoraging yet. Was wondering if I should do both hoses while I'm there and messy.
Also, is it best done from the top or from the bottom?
PostPosted: Sun Jun 02, 2019 9:33 pm
Only need to worry about the high pressure line. Need to do it from the bottom.
-Andrew-
There are no new unread posts for this topic. Power steering Pressure Hoses
dz09x
Sat Jun 23, 2012 12:36 am
Archon View the latest post
There are no new unread posts for this topic. Power Steering
CMS07
Thu Apr 28, 2011 12:04 pm
CMS07 View the latest post
There are no new unread posts for this topic. No power steering??
flatlander745
Thu Oct 25, 2012 10:37 am
flatlander745 View the latest post
There are no new unread posts for this topic. Power steering fluid
00ssei
17
4155
Wed Sep 10, 2008 4:02 pm
00ssei View the latest post
There are no new unread posts for this topic. Power Steering Pump Going Bad?
Ponch 04
Thu Dec 18, 2008 12:00 am
Users browsing this forum: No registered users and 16 guests
