It is currently Sun Jun 07, 2020 12:05 am
PostPosted: Fri May 17, 2019 6:02 pm
Year and Trim: 2000 Pontiac Bonneville SE
I recently noticed that one of my air lines is broken on my 2000 SE. has anyone replaced these lines before? If so where can I find them?
1993 Buick Regal GS Coupe
PostPosted: Fri May 17, 2019 9:47 pm
2005SLE WHITE
1975 MONTE CARLO
I had a line break on my 2005SLE.
I used the following:
Monroe AK29 line kit from Amazon $10.94
SMC KQ2H01-00A connector from Amazon $3.99.
Instead of replacing the whole line I just cut it off and spliced in a new piece with a connector.
It worked great with no problems.
PostPosted: Sat May 18, 2019 6:14 pm
Thanks for the great idea!
PostPosted: Sat May 18, 2019 6:57 pm
2005SLE WHITE
1975 MONTE CARLO
You are more than welcome!
PostPosted: Sat May 18, 2019 7:47 pm
2005 GXP
You can use a brass compression fitting for 1/8" line if the existing line is cut. A local hardware store should have a splice fitting.
No need to buy the Monroe kit.
https://shop.advanceautoparts.com/p/ame ... lsrc=aw.ds
PostPosted: Sat May 18, 2019 9:33 pm
2005SLE WHITE
1975 MONTE CARLO
What the Monroe kit does is give you the correct fitting to snap on to the shock.
In my case it was cut right where it goes onto the shock and I did not have enough line to make a splice.
That is why I bought the kit.
PostPosted: Mon Jun 03, 2019 6:17 pm
So I just need to put both ends of the line into that connector and close it and it's good to go?
PostPosted: Mon Jun 03, 2019 8:06 pm
2005SLE WHITE
1975 MONTE CARLO
Where is the line broke?
Mine was broke right by the connector that goes on the shock.
I used the kit for the new air line with the connector on it.
I then cut the line off and spliced it with the 1/8" X 1/8" fitting.
Everything worked great.
PostPosted: Wed Jun 05, 2019 10:25 am
yes, that is the basic process, but, you should follow the instructions in the kit since you're Nancy...lol(inexperienced).
PostPosted: Thu Jun 06, 2019 11:17 pm
It broke about 6 inches from where it goes on to the shock.
PostPosted: Fri Jun 07, 2019 4:11 pm
then its perfect - clamp union on the line on one end and your new line on the other end or you can use the existing line that goes to pump
hard to direct you properly without eyes on.
There are no new unread posts for this topic. 2001 Bonneville Rear Shock Air Lines
dougtoth
Mon Jan 01, 2018 10:54 am
dougtoth View the latest post
There are no new unread posts for this topic. Rear shock mounts 2000 sle, help?
MrJiggy716
12
1575
Thu Aug 08, 2013 2:32 pm
MrJiggy716 View the latest post
There are no new unread posts for this topic. 2000 SLE Rear Shock lower mount bolts stuck/questions
Bonneville'sRock
Tue Feb 11, 2014 1:18 am
There are no new unread posts for this topic. Rear Shock Conversion
Black Pearl
32
12570
Fri Jan 28, 2011 10:43 pm
willwren View the latest post
kennyz
Sun Aug 23, 2015 12:08 am
Users browsing this forum: Google [Bot] and 12 guests
