It is currently Wed Feb 26, 2020 12:17 pm
 Post subject: 2005SLE Question
PostPosted: Sun May 05, 2019 12:18 pm
2005SLE WHITE
1975 MONTE CARLO
I just bought a 2005SLE in real nice shape.
Color is a pearl white and it has 102K on it.
My question is this.
It has an aftermarket remote start on it.
I am not a fan of add on after market products.
I plan on taking it off as my wife and myself will not use it.
My son had one on his Bonneville and after 2 years it must to have shorted out.
His battery kept dying every morning and I had him disconnect it and it took care of the problem.
The weird thing on my car is that the buzzer does not work with the key in the ignition and the door open.
It also does not buzz when the lights are on and you shut off the car and open the door.
Is it possible that this remote start has something to do with it?
Or is it another issue.
Thanks.
 Post subject: Re: 2005SLE Question
PostPosted: Sun May 05, 2019 8:56 pm
my 2000 came with a xm reveiver - I dont use it but leave it alone cause everything works.
the chimes aren't a big deal - you dont know what the last guy did
did you check the chime module itself?
PostPosted: Mon May 06, 2019 12:37 am
There is no chime module in the 2000+ Bonneville. Chimes are produced by the factory radio by modules signalling over the Class 2 Serial Data Bus to sound a chime. If someone installed an aftermarket stereo but did not add an aftermarket chime module, no chimes will be heard. Personally, I think they are important because it may be the only thing that alerts you to a problem while driving down the road. If the door and key in ignition chimes aren't working, my bet is that the other more important system warning chimes aren't either.
PostPosted: Fri May 10, 2019 8:27 pm
2005SLE WHITE
1975 MONTE CARLO
The problem is solved.
I had my radio up by Andrew to get new bulbs put in it.
When I got the radio back and put it back in the car the buzzers started working again.
I did not realize that the security system or the warning buzzers are connected through the radio.
Learn something new every day.
PostPosted: Sat May 11, 2019 3:13 am
The security system is a separate system with its own module. All the warning chimes (door open, key in ignition, any alerts on the instrument cluster, etc.) are all generated using the radio.
The radio has its own security built in. It prevents installing it in a different vehicle without a procedure to unlock it. This has nothing to do with the vehicle theft deterrent system.
PostPosted: Sat May 11, 2019 8:38 am
2005SLE WHITE
1975 MONTE CARLO
O.K.
Thanks for the info.
Just out of curiosity where is the security system module located on my 2005 SLE?
PostPosted: Sat May 11, 2019 11:37 am
The PASS-Key III module is in the instrument panel, to the left of the radio, behind and underneath the ignition lock. It isn't really easy to access.
PostPosted: Sat May 11, 2019 3:39 pm
2005SLE WHITE
1975 MONTE CARLO
Great.
Thank you!!!
There are no new unread posts for this topic. 2005SLE LED Headlights
dougtoth
Thu Jan 10, 2019 12:08 am
J Wikoff View the latest post
There are no new unread posts for this topic. Re: question for you pls. Cabin air filter question.
sonoma_zr2
Tue Aug 16, 2011 10:31 pm
There are no new unread posts for this topic. a/c question
chuy10
Sun Apr 27, 2014 9:46 am
Jrs3800 View the latest post
There are no new unread posts for this topic. A/C question among others
my4x4cj7
Thu Jul 05, 2012 10:41 am
RogueSSEi View the latest post
There are no new unread posts for this topic. Gas cap question...
smokinssei02
Mon May 28, 2012 9:09 pm
smokinssei02 View the latest post
