It is currently Wed Feb 26, 2020 12:31 pm
 Post subject: gas release switch
PostPosted: Tue Apr 23, 2019 11:47 pm
Year and Trim: 2001 sle
Just found out I have a locking gas door but can't find the release button ? They are usually beside the drivers seat it's not working but the gasket is leaking want to fix it and get it back to locking but how do I open it after. I :dontknow: :dontknow: found the trunk release
 Post subject: Re: gas release switch
PostPosted: Wed Apr 24, 2019 11:30 am
Year and Trim: 01 SSEI (black)
00 SSEI (green)
6-7
https://my.gm.com/content/dam/gmownerce ... owners.pdf
PostPosted: Wed Apr 24, 2019 1:25 pm
The gas door lock works in conjunction with the door locks. Lock the doors, and it would lock the gas door. Unlock, and it releases it. Failure of that lock is quite common. Many just remove, or disable it.
PostPosted: Fri Apr 26, 2019 11:27 am
YES, you can open the trunk, peel back the grey liner and find the manual release,:its a plastic 3inch tab connected to a wire - pull it and open gas door.
PostPosted: Fri Apr 26, 2019 10:36 pm
There is actually a cross cut in the trunk liner for the manual release to pass through. The backing on the release pull tab allows it to stick to the liner in plain view to access when necessary. If everything is installed correctly, there should be no need to peel back the trunk liner. It sounds like someone probably had the trunk taken apart and didn't reinstall things correctly.
PostPosted: Sat Apr 27, 2019 9:16 am
My gas door release solenoid gets flaky and doesnt always release. Got tired of having to open my trunk and pull the release everytime I got gas, so I just bent back the catch on the door so the solenoid doesn't catch anymore. Not too worried about someone messing with the fuel tank.
There are no new unread posts for this topic. Broken Hood Release
Ronnyboy
Sat Jun 02, 2012 7:57 pm
There are no new unread posts for this topic. Clunk when I release the brake
brownbrentm
Fri Sep 09, 2011 9:54 pm
Bing View the latest post
There are no new unread posts for this topic. '05 bonneville gxp trunk release?
Rekhavoc
Thu Nov 14, 2013 1:26 am
bobgto65 View the latest post
There are no new unread posts for this topic. Attachment(s) trunk release button location
jchristine23
28
8537
Mon Jun 27, 2011 4:23 pm
jchristine23 View the latest post
There are no new unread posts for this topic. Interior hood release---broken
bc21
Tue Dec 18, 2012 7:04 pm
bc21 View the latest post
