It is currently Wed Feb 26, 2020 1:03 pm
PostPosted: Sat Apr 20, 2019 10:32 pm
Year and Trim: 2000 se
2000 bonne se, giving me codes P0401 and P0420.
I have checked the EGR passage, replaced the EGR, cleaned the throttle body, inspected and fixed a couple vacuum leaks, replaced the fuel filter, did plugs and wires late last year, and the MIL is on almost constantly.
Even thought about replacing the MAP sensor after reading an article, but it is progressively getting harder to start and not throwing a MAP code, taking longer to crank before firing. Usually worse when close to closed loop temp rather than stone cold.
This, along with it needing front brakes, rear warped rotors, the blower motor making noise, valve cover leaks, A/C bleeding off during a season with no leaks I can find even with dye, and a recent problem appearing with door locks, trunk release, turn signals misbehaving, and "check body" light coming on whenever it wants to, I am pulling my hair out.
PostPosted: Sun Apr 21, 2019 9:24 am
Have you replaced the Fuel Pressure Regulator and/or the Crank Position sensor?
"Penelope" - 2003 SLE - 203k Miles
"Sydney" - 2000 Honda S2000 - 71k miles
PostPosted: Sun Apr 21, 2019 8:01 pm
A/C leak may be in evaporator( hidden in dash. if he unit works, you may want to ry a sealant.
brakes are normal maintenance for cars - make sure all lug nuts a tourqed to 100/f/lbs and you wont have disk warp any more.
first try cleaning the Maf sensor.
if you have scantool that pulls live data, the MAP should be reading the same as ambiant air pressure. in your town.
check weather for barometric reading.
with key in on position, but engine off, your data should be very close to weather data: around 1 atmosphere( 100 kpa or 14.7 psi)at sea level.
if the reading is way off, the map is funky. dont give up: your almost there.
PostPosted: Mon Apr 22, 2019 9:32 am
Thanks. I cleaned the MAF last year, but will try it again.
always torque my car lugs to 90, and one ton lugs to 120. I know the rear rotors are borderline turnable, but the front pads are down.
I'll check MAP readings, even though I replaced that this week too.
PostPosted: Mon Apr 22, 2019 9:33 am
No, I have not.
There are no new unread posts for this topic. 3 issues with 2000 Bonneville SE
dbaatz
11
2551
Mon Apr 04, 2011 11:10 pm
dbaatz View the latest post
There are no new unread posts for this topic. RADIO ISSUES 2000 BONNEVILLE
jennifer1234
Sat Oct 19, 2013 9:21 pm
jennifer1234 View the latest post
There are no new unread posts for this topic. 2000 SE, minor issues
MattStrike
Mon Aug 22, 2016 11:48 am
There are no new unread posts for this topic. 2000 running issues
archaicguy
Sun Aug 18, 2019 10:09 pm
There are no new unread posts for this topic. 2000 Bonnie SE stalling issues
Bad67bird
49
4719
Wed Nov 08, 2017 2:09 pm
MKMike View the latest post
Users browsing this forum: No registered users and 14 guests
