It is currently Thu Jun 27, 2019 2:26 am
 Post subject: engine harness damaged
PostPosted: Tue Apr 09, 2019 11:20 am
On my 2002 SSEi I have damaged wires in multiple locations on the engine harness. On the front 3 fuel injectors, BCS, MAF sensor, cmp sensor. Should I replace/repair each connector, or just get a used complete harness from the junkyard?
PostPosted: Tue Apr 09, 2019 12:25 pm
Depends what kind of work you prefer, fixing or replacing. I'd guess they will both be the same amount of work required. If you're looking for a good harness I sell them.
-Andrew-
PostPosted: Wed Apr 10, 2019 1:19 pm
if you use a multimeter with continuity reading, you can do it yourself. you will use the cont. reading to be sure you have no breaks or damaged circuits within the harness.
There are no new unread posts for this topic. Shop charge to replace the main engine harness
max harris
Mon Oct 12, 2015 8:32 pm
This topic is locked, you cannot edit posts or make further replies. Damaged 2001, Technical Drivetrain Question
kennedyrec
12
1276
Thu Feb 14, 2013 8:24 pm
Jrs3800 View the latest post
There are no new unread posts for this topic. o2 harness
irish91983
Thu Jun 21, 2012 3:29 am
irish91983 View the latest post
There are no new unread posts for this topic. rear right WSS harness
dz09x
Mon May 05, 2014 7:50 pm
dz09x View the latest post
There are no new unread posts for this topic. ICM wiring harness
bonnie_99
Sun Apr 05, 2015 9:05 am
Users browsing this forum: No registered users and 14 guests
cron
