It is currently Tue Sep 17, 2019 1:12 pm
PostPosted: Mon Mar 04, 2019 1:59 pm
Year and Trim: 2005, SE, V6, 3.8
Hi guys, my Bonne went out on the hw on friday due to the fuel pump harness disconnecting on the rear passenger side behind the tire. I reconnected, tried to start and had no luck. I stopped attempting to start the engine after I drained the battery :sadeyz: today I was able to get the battery recharged and still, she won't start, please help. here is a video
https://youtu.be/GIfSgn4msT0
PostPosted: Mon Mar 04, 2019 3:35 pm
Start with the basics, check for spark and fuel.
PostPosted: Mon Mar 04, 2019 9:35 pm
Year and Trim: 2002 se
Spray starter fluid through open throttle. If the car sputters then it is a fuel problem. If it just cranks suspect electrical problem.
PostPosted: Tue Mar 05, 2019 10:46 am
Can you hear the fuel pump running? Why would the fuel pump harness be disconnected? It is isolated from everything and should have a terminal lock on the connector. Sounds like we don't have the whole story.
-Andrew-
PostPosted: Tue Mar 05, 2019 12:11 pm
Yes, I can hear it running. It disconnected while on the highway, I believe there was some stuck on the side of the tire, im not sure but I had to reconnect to get it started again, the it went back out.
There are no new unread posts for this topic. just bought the l26 (story attached)
Franksdad
Thu Nov 21, 2013 10:28 am
There are no new unread posts for this topic. Werid engine noise - Vid attached
WhiteArrow3800
11
1767
Mon Dec 31, 2012 4:38 pm
There are no new unread posts for this topic. Car won't start, won't respond to a jump start anymore
Peachrules14
Fri Nov 14, 2014 2:59 pm
zamjohn View the latest post
There are no new unread posts for this topic. Intermittent Rough start - start/stall
38bonne
Fri Dec 26, 2014 7:52 pm
There are no new unread posts for this topic. Hesitation and hard start on start up
SPLLOUDER
Mon Apr 27, 2015 7:24 pm
96 SSEi View the latest post
Users browsing this forum: No registered users and 14 guests
