It is currently Sat Apr 20, 2019 8:45 pm
PostPosted: Mon Feb 11, 2019 9:59 pm
Year and Trim: 2000 SSEi Galaxy Silver
It appears that the "fuel pump control module" was only used on the 2000 Bonnevilles. I found the schematic for the 2002 models posted and it sure enough showed no "fuel pump control module" in the fuel pump circuit: the fuel pump motor is connected directly to the B+ relay feed output and ground. When I suspected that my module was bad, I jumpered my fuel pump relay B+ output around the control module and it ran fine. Putting the control module in the circuit causes hard starting and running. So I question: do I REALLY need that control module??? Or can I just bypass it - would it hurt anything to just bypass it? BTW, both the 2000 and the 2002 Bonnevilles use the SAME fuel pump.
- Joe
PostPosted: Wed Feb 13, 2019 12:25 pm
It should be fine to bypass the module.
There are no new unread posts for this topic. Wire harness between Fuel Pump and 2-speed Controle Module
golfyeti
Tue Apr 20, 2010 11:10 am
There are no new unread posts for this topic. Fuel Pump Control - SSEi
Archon
Mon May 19, 2008 11:14 pm
Archon View the latest post
There are no new unread posts for this topic. Fuel pump swap?: 2000 LeSabre(L36) to 2000 SSEi(L67)
Junior28
Tue Jun 24, 2014 2:45 pm
There are no new unread posts for this topic. 2002 pontiac bonneville ssei climate control module
phatdaddy215
Sat Feb 20, 2016 3:17 am
ddalder View the latest post
There are no new unread posts for this topic. Body Control Module - Rear Integration Module
2000Silverbullet
34
3261
Fri May 22, 2015 4:07 pm
