It is currently Tue Jun 18, 2019 5:07 am
 Post subject: supercarger question
PostPosted: Sun Feb 10, 2019 11:17 am
Year and Trim: 2005 sle
can I install supercharger from 02 to 05 non supercharged engine? I have whole car so I can change ecu if needed.
thanks gene
 Post subject: Re: supercarger question
PostPosted: Sun Feb 10, 2019 5:30 pm
You will need to swap everything from the heads up on the NA block and get a custom tune because the non-supercharged engine has higher compression.
http://www.grandprixforums.com/3-8l-v6- ... -info.html
"Penelope" - 2003 SLE - 190k Miles
"Sydney" - 2000 Honda S2000 - 63k miles
PostPosted: Sun Feb 10, 2019 11:20 pm
If you have the whole car, you may was well just drop the subframe with the drivetrain attached, and swap the whole thing. Not only is it a bit more work to fit a supercharger to a NA car, but, you would still be missing out on the strengthened internals of the engine, the proper cooling for the drive train, as well as the HD variant of the transmission, and the gearing that may go with it.
PostPosted: Tue Feb 12, 2019 10:23 am
The Series 2 NA engines handle boost just fine, you just have to account for the higher compression ratio. In the 2000+ form there wasn't much of an upgrade for the cooling system, and the HD trans doesn't actually strengthen any of the known weak points of the transmission. And the NA gearing is better as well since it is shorter!
Plus you get to replace a bunch of gaskets and fluids if you do a top swap. It's actually very popular in the w-body world, especially in turbo applications, to go for the NA motor because of some of this stuff. Especially the higher compression.
There are no new unread posts for this topic. Re: question for you pls. Cabin air filter question.
sonoma_zr2
Tue Aug 16, 2011 10:31 pm
There are no new unread posts for this topic. PCS QUESTION
bslayer
Sat Jan 01, 2011 8:00 pm
There are no new unread posts for this topic. EGR question
TheMannn
Mon Dec 03, 2012 11:52 am
TheMannn View the latest post
There are no new unread posts for this topic. Just a Question
Levi
Tue Nov 12, 2013 7:08 pm
Levi View the latest post
There are no new unread posts for this topic. a/c question
chuy10
Sun Apr 27, 2014 9:46 am
Jrs3800 View the latest post
