It is currently Tue Jul 14, 2020 2:22 pm
Post new topic Reply to topic  [ 30 posts ]  Go to page Previous  1, 2
PostPosted: Thu Mar 14, 2019 1:14 pm
Year and Trim: '93 SSEi
'05 STS-4
'97 LeSabre
Anything I've had break on a 4t65 has mostly been of my own doing. The only time I've had an issue with one was the last time I got one from the U-pull ($80) and slapped it in without checking any of the electronics or really going through it. Most of it's issues are fixed with a shift kit and trans cooler, and if it's older than 2003 the 4th hub.
PostPosted: Tue Mar 26, 2019 5:03 am
Rebuilds are often questionable because some shops just do not spend the time nor money to rebuild them properly. They cut corners. Often times parts that should be replaced are "reconditioned", meaning cleaned up, checked for specs, and thrown back in.
As for the track record on the 4T65, yes, we hear all the bad reports of them. But how many were installed over the years? 100s of thousands? Millions? Statistically their track record is probably decent. Worse than Toyota or Ford or...? Maybe. I don't know. But to assume they're all bad may not be justified. There are hundreds of thousands of cars out there with 4T65s that are still cranking along.
There is perhaps not much comparison with Toyota because they are one of the top dependable brands.
Gm transmissions are typically way better than Ford or Chrysler. Well, ANYthing is better than Ford transmissions.
My room mate and I, between us, have owned a few GM cars (90 cavalier, 99 lesabre, 94 Grand prix, 97 grand am, 99 grand am, 00 Bonneville) and the only problem I have seen was my 90 Cavalier had a torque converter clutch solenoid failing. I think at some point before my room mate bought the Bonneville, the trans had been rebuilt because the fluid is cherry red. None of the other fluids looked good so I doubt they made a special effort to change the trans fluid.
But anyways, my experience is GM transmissions are not overly troublesome. HOPEfully the rebuild in my room mate's car holds up, I know what I said about rebuilds earlier.
Ford ones though, do not get me started.
PostPosted: Thu Mar 28, 2019 9:02 am
Year and Trim: 2003 SSEi
Wow, so many responses!
Update coming soon everyone. Car should be finished by the weekend and I'll post info and pictures once I get it back home.
PostPosted: Sun Apr 07, 2019 8:27 pm
nos4blood70 wrote:
188k on mine without any major issues. Granted it's an 03 and I've added a shift kit and trans cooler. I've also been religious about fluid changes and have a nice tune on the car as well.
*shoot* situation for OP one way or another, but depending on the shape of the car and how much work it actually needs, I'd still consider a new rebuild. It's gonna be rough finding another similar car for the price after selling the Bonne.
I installed an HD cooling radiator on my 03 several years back, along with a shift kit, and Dexron 6 fluid changes since I bought it.. 160k on the clock.. Not as may miles as you, but shes still kicking..lol
Heat is a huge enemy of these transmissions.. I don't care what GM says, 160F trans temps are optimum in my eyes.. If the fluid becomes brown the trans has already been overheated and the damage has begun.. All 00-05 3800 Bonneville did not have a good cooling system, The radiator was just too skinny and allowed the trans to get too hot.
PostPosted: Mon Apr 08, 2019 8:38 am
I think the stock cooling system was fine for the motor, but the addition of an extra transmission cooler and a 180* thermo and tune are a big help all around!
I did the same thing you did. Added shift kit, cooler, and I have a tune for the 180 thermo. I rarely see over 160 degrees for the trans unless it's real hot. I actually end up blocking the thing for half of the year. The car climbed and descended Pikes Peak without any issues or big heat.
PostPosted: Fri Apr 12, 2019 11:34 am
Hey so I was going to post an update with pics, but I'm just going to type it out instead since I never seem to find the time to put everything together.
I ended up having the car towed down to back where I grew up (5+hrs away). My Dad, who is recently retired, decided to make an adventure of it and rented a U-Haul and a car trailer, leaving me his wheels for two weeks to get around.
The transmission has been completely rebuilt to well above the standard by one of the best GM Transmission repair shops anywhere.
Despite the fact that I am a grown ass adult, my parents were nice enough to foot the bill so long as I forgo my next several years of birthday and Christmas gifts.
I've been taking it easy on the car since I've had it back and yesterday I finally decided to push it a little to make sure everything was, in fact, in order.
It wasn't.
But it wasn't the transmission! Generic OBDII code for Cylinder #4 misfire. (which is of course one of the ones on the back of the engine).
I left work early yesterday as I wasn't feeling well (this has now turned into a full blown illness, but at least I got the work on the car out of the way as I descended into my sickly state) and started troubleshooting.
It wasn't the spark plug, although they're exhibiting signs the engine is running hot. I replaced the thermostat with a 180 degree T-stat, but I should also install new plugs that are a heat range colder I think.
Anyway, I switched #4 and #2 and got the same code when I took it onto the highway and laid into the throttle.
The new ZZP wires looked good, no burns or anything, so the next thing I tried was the ZZP coil pack. I swapped an old OEM one in and sure enough, no more misfire.
Disappointing as hell considering I just installed them at the end of last summer, but at least I fixed my problem. I'll order fresh OEM coil packs next time I have some cash to put an order through with RockAuto.
The car really scoots, and the transmission feels solid again. Here's hoping I can get several more years out of this beast.
Thanks everyone for commenting and offering advice!
PostPosted: Sat Apr 13, 2019 8:03 am
The ZZP coils and wires have been known to be of somewhat spotty quality over the years. I wouldn't worry too much about it!
Glad to hear you got it repaired and are enjoying it again.
PostPosted: Sat Apr 13, 2019 9:27 am
so after two pages, the first response was correct? lol...good you got it sorted.
PostPosted: Sat Apr 13, 2019 9:38 am
Nah, I think his issue still required a rebuild trans but after it all the ZZP ignition stuff decided to *shoot* to bed. Just bad luck and timing.
PostPosted: Mon Apr 15, 2019 2:07 pm
^ Yes, that.
The misfire may have been there all this time to a lesser extent or it may have just started recently.
It may have caused further damage to the transmission, but may not have been the only problem with it. The guy who rebuilt it said he saw things buggered up with the third clutch (going off memory, I know nothing of trans internals) he had never seen before and he has rebuilt dozens of these.
Anyway, Transmission fixed. Misfire also fixed. Here's hoping only little things from now on. That being said I need to go buy a new headlight. The fun never stops.
There are no new unread posts for this topic. slipping transmission
wiro01sle
Wed Jan 05, 2011 11:47 am
There are no new unread posts for this topic. Bad PCS? Transmission Slipping
pinstriper38
Thu Oct 15, 2015 8:26 pm
pinstriper38 View the latest post
There are no new unread posts for this topic. transmission slipping at high rpm?
BrianT
Tue Mar 24, 2015 8:10 am
There are no new unread posts for this topic. Strange vibration and slipping Transmission
2000Silverbullet
15
2178
Tue Jun 09, 2015 1:26 pm
Archon View the latest post
There are no new unread posts for this topic. transmission one year only?
02ssei
Mon Sep 26, 2011 12:20 pm
candimann31 View the latest post
Users browsing this forum: Watcher and 16 guests
