It is currently Tue Feb 19, 2019 11:44 am
 Post subject: High idle issue
PostPosted: Wed Feb 06, 2019 7:32 pm
Year and Trim: 2000 se
The car for the past month maybe month and half has been starting In the morning and at idling at 1500 then it would idle down after awhile if I left it, I just figured with the cold weather that was normal usually I just warmed it up for a bit then went to work and all was fine a few minutes later down the road. Well today I started the car and it was at 2500 and won’t idle down, if I throw it in gear it will go down to 1500 but that’s it, back in park and right back up? It’s giving me no codes, so I’m lost what it is at this point? When I was chasing the misfire thing last year I replaced the tps, cleaned the iac and egr too. That iac are u able to pull and press in the Pintle? It moves but very hard each way wether I pull on it or push it in, that was today when checking if it was dirty etc.
 Post subject: Re: High idle issue
PostPosted: Fri Feb 08, 2019 10:38 am
Update, was a faulty TPS Which was new in july!
There are no new unread posts for this topic. High idle and Cruise 'idle'...
Z-type
11
3061
Mon Jul 25, 2011 11:14 pm
Z-type View the latest post
There are no new unread posts for this topic. High Idle
BonneBill
Fri Jan 15, 2010 3:40 pm
BonneBill View the latest post
There are no new unread posts for this topic. High idle after some work done
dz09x
Thu Sep 06, 2012 12:31 am
nickburgundy View the latest post
There are no new unread posts for this topic. High idle occasionally
FiendScurro
Thu May 07, 2015 10:00 pm
There are no new unread posts for this topic. High idle when cold
DRC
Sun Nov 04, 2012 1:17 pm
DRC View the latest post
