It is currently Fri Apr 26, 2019 5:40 am
 Post subject: Oil pressure sensor
PostPosted: Fri Jan 18, 2019 1:23 am
So, while driving home from work this evening, I came upon a right-hand turn I had to make at a red light. I stop, then go. Spin the tires a bit on accident, and then start driving along. However, now my oil pressure sensor is off a bit. Normally it sits around 40, maybe 3 to 4 pegs above. Now, it sits at the big peg in-between 40 and 120, maybe 2 to 3 pegs above that. Engine ran fine, nothing suspicious under the hood; the sensor was reading normally before this turn. My sensor went bad, didn't it? Mind you, it isn't pegged at 120.
That being said, would it be easier for me to replace the sensor, or to take it to a shop? If I take it to a shop, I'll see if they can do another thing or two to her.
(Note: I read the common problem write-up about this.)
'02 Pontiac Bonneville SE 106k miles, N/A, SSEi exhaust system, boat roller mount.
 Post subject: Re: Oil pressure sensor
PostPosted: Fri Jan 18, 2019 3:24 pm
It is a super easy replacement, it sits just above the oil filter. They are relatively cheap, so I'd save and do it yourself.
PostPosted: Fri Jan 18, 2019 3:32 pm
Year and Trim: 2000 SLE 2005 SLE
1975 Monte Carlo
It is an easy fix.
I bought a 27mm deep socket that works great.
PostPosted: Fri Jan 18, 2019 5:04 pm
Will do. Thanks fellas
There are no new unread posts for this topic. Oil Pressure Sensor is pegged
mrwildroot
18
2685
Sun Jul 21, 2013 5:00 am
mrwildroot View the latest post
There are no new unread posts for this topic. High Pressure sensor for A/C
leatherneck
Wed Jul 20, 2011 10:56 pm
leatherneck View the latest post
There are no new unread posts for this topic. Attachment(s) tank pressure sensor
96 SSEi
Tue May 05, 2015 8:38 pm
96 SSEi View the latest post
There are no new unread posts for this topic. oil pressure sensor question
Franksdad
Thu Dec 12, 2013 3:06 pm
Franksdad View the latest post
There are no new unread posts for this topic. Oil Pressure sensor easy replacement
Night Crawler
Sun Apr 15, 2012 6:52 pm
Users browsing this forum: Exabot [Bot], ItsJessee and 9 guests
