It is currently Sat May 30, 2020 4:49 pm
PostPosted: Sat Dec 29, 2018 5:22 am
So the master cylinder reservoir was not dry, but anyways I had to replace the two lines from the M.C to the ABS module.
Is there any special way to go about bleeding it? Do I just pop open the caliper screws and wait for things to bleed like normal?
Right now it has little or no braking power. It barely had any before because one of the M.C. lines was leaking real bad.
Thank you.
PostPosted: Tue Jan 22, 2019 4:19 pm
hi, i would bleed all 4 wheels .
fill mc.
pump brakes till it stiffens -
with pedal down
open bleed screw - close bleed screw
now let pedal up and pump
repeat till just clean fluid comes out
do this to all wheels
go for drive and engage abs on sand
if it still soft, bleed again all 4
PostPosted: Tue Jan 22, 2019 5:30 pm
Bleed all 4 like normal. You definitely have air in the lines.
There are no new unread posts for this topic. Question about bleeding brakes, master cylinder and ABS
PAGNAM
Tue Nov 12, 2013 6:25 pm
xcbullet View the latest post
There are no new unread posts for this topic. Can't bleed my brakes!
slanej
Tue Sep 03, 2019 11:12 pm
Oldman View the latest post
There are no new unread posts for this topic. do I need to bleed the brakes?
Hans
Fri Nov 07, 2008 8:45 pm
J Wikoff View the latest post
There are no new unread posts for this topic. master cylinder harness
unclebubbaSE
Mon Mar 02, 2015 9:53 am
There are no new unread posts for this topic. Master cylinder/line replacement questions
CRaZYsid
Sat Mar 29, 2014 4:11 am
CRaZYsid View the latest post
Users browsing this forum: No registered users and 24 guests
