It is currently Tue Feb 19, 2019 7:09 pm
 Post subject: Rear rotors
PostPosted: Sun Dec 02, 2018 4:05 pm
How can I tell when I need to have my rear rotors replaced?
I had my front rotors replaced in September (I think), and I know that there is a pulsing feeling in the brakes when the front rotors need to be replaced. But I don't know what to listen/feel for - in terms of the rear rotors.
As far as I know, the rear rotors are stock.
'02 Pontiac Bonneville SE 105k miles, N/A, SSEi exhaust system.
 Post subject: Re: Rear rotors
PostPosted: Sun Dec 02, 2018 5:45 pm
The "correct" method is to measure the thickness. Rotors will have a discard thickness cast into them and anything less than that number (after machining) must be replaced. The idea is to generally measure each one in several places.
According to the service manual, the minimum is 9.0mm or 0.354" (for rear rotors on the 2002). Again, if the number cast into the rotor is different, use that value instead. I expect the numbers are the same for others in this body style, but I didn't check so I'm being specific to your car.
Personally, I replace rotors every time I replace pads because they just aren't that expensive anymore. If you reuse rotors, they "should" be machined and with this cost, it's the same or less expensive to just buy new (although many people don't do this). Machining of course takes precious metal off and the thinner they get, the sooner they'll start to warp. Rear brakes provide a fraction of your overall braking and won't typically wear or warp as fast (unless you have a stuck caliper).
I'm sure there will be several others chime in as well, but this is my two cents worth. There are three things on a car I decided many years ago never to "cheap out" on... Brakes, tires and suspension/steering components.
Further to your post, "pulsing" is not an accurate or industry accepted means to determine if rotors are worn to the point of needing replacement. This simply means they have heated and cooled to such an excess that they have warped. I've seen almost brand new, low end rotors warp very quickly even though by measurement, they are well within tolerance. Warped rotors can be machined and re-used as long as the final thickness meets/exceeds the specification. Again, for the reasons above, I buy quality and replace every time.
I'm not a crazy driver, but I never have problems (pulsating, squealing, etc) with my brakes.
PostPosted: Mon Dec 03, 2018 1:05 pm
I agree with Darcy. The only thing that I would add is that a visual inspection is limited, as you can only see the front of the rotor. The dust shield prevents this on the back of the rotor, which often can be quite pitted. As you believe that yours are original, that's likely to be the case. The only real way to check is to pull the rotors. If you're going to do that, may as well replace the pads and rotors at the same time.
PostPosted: Mon Dec 03, 2018 2:27 pm
Grab some centric or ACDelco rear rotors and pads off Amazon and send it. So inexpensive and quick to do.
There are no new unread posts for this topic. Noisy Rear Rotors After Replacement
harrydunn
Tue Aug 12, 2008 11:12 pm
Archon View the latest post
There are no new unread posts for this topic. Hole size for drilling rear rotors?
xcbullet
22
1017
Thu May 22, 2014 1:41 am
xcbullet View the latest post
There are no new unread posts for this topic. Front Rotors, Which rotors will warp easily?
Hans
14
2000
Tue Jun 30, 2009 2:43 pm
There are no new unread posts for this topic. rotors
spoiledred94
33
1595
Sun Aug 10, 2014 1:36 pm
MrT View the latest post
There are no new unread posts for this topic. Rotors and pads
FiendScurro
Wed Sep 19, 2012 2:46 pm
Users browsing this forum: Exabot [Bot], Google [Bot], peter and 7 guests
