It is currently Wed Apr 24, 2019 10:50 am
PostPosted: Thu Nov 15, 2018 9:43 am
Year and Trim: 2000 SLE 2005 SLE
1975 Monte Carlo
Have 2000SLE where car will not crank or start early in morning when it is cold.
Have put in new battery,new starter and new starter relay.
It seems like something is wrong possibly with the ignition switch or the VAT or brain box.
When key is in run position the dash lights and the DIC lights up.
When key is in start position the dash lights are still on but the DIC does not light up.
You can hear the relay clicking but the car will not crank.
When I try it later in the day when the temperature warms up it will crank and start.
You can then shut it off and restart it with no problem.
Is it something to do with a resistor when it is cold?
Should mention that car has 355,000 miles on it.
Thanks.
PostPosted: Thu Nov 15, 2018 12:51 pm
The 2000+s don't use the resistor type of security system. This is a older TSB that could be your problem.
File In Section: 08 - Body and Accessories
Bulletin No.: 00-08-49-015
Date: November, 2000
Subject:
Intermittent No Start/No Crank
(Replace Ignition & Start Switch Assembly)
Models:
2001 Oldsmobile Aurora
2000-2001 Pontiac Bonneville
Condition
Some customers may comment that the ignition and start switch assembly in the above listed vehicles may not operate properly resulting in an intermittent no start/no crank condition.
Cause
This condition may be due to plastic particles interfering with the electrical contacts of the ignition switch assembly.
Correction
An improved ignition switch assembly, P/N 25721650, is now available from GMSPO.
Refer to the Instrument Panel, Gauges and Console sub-section of the appropriate Service Manual for replacement procedures.
PostPosted: Thu Nov 15, 2018 4:11 pm
1975 Monte Carlo
Thank You.
I will try cleaning it first.
If that doesn't work I will replace it.
PostPosted: Thu Nov 15, 2018 4:55 pm
1975 Monte Carlo
Question.
If I replace unit with 25721650 will I have to get new keys also?
PostPosted: Fri Nov 16, 2018 1:00 pm
I don't believe so. I think that it just replaces the switch, not any of the other circuitry that would affect the security feature, or the keys.
PostPosted: Fri Nov 16, 2018 5:39 pm
1975 Monte Carlo
O.K.
Thanks.
PostPosted: Sun Nov 25, 2018 4:22 pm
1975 Monte Carlo
We were in the junk yard (LKQ) on Friday and took off an ignition switch assembly from a Bonneville.
There was a metal cable on the back of it that we had to cut off to take it out.
Question?
What is this cable and were does it go or do?
Also is there a way to release this cable without cutting it?
Thanks.
PostPosted: Tue Nov 27, 2018 8:32 pm
The only thing that I have been able to find is that it is likely for the shift lever lock. All instructions for removal of everything attached to the switch is that there should be clips along the side.
PostPosted: Tue Nov 27, 2018 9:35 pm
1975 Monte Carlo
O.K.
Thanks.
PostPosted: Wed Nov 28, 2018 1:27 pm
You may want to check with Andrew. He has all the experience with these cars. I haven't had to deal with your problem.
PostPosted: Fri Nov 30, 2018 12:54 am
I have a cold weather "no crank" issue (see my post "passkey 3 voodoo".
Try what I've been doing. When you get in the car, put the key in ignition (count to five), turn key to ON (count to five), then turn to start and see if it cranks. I've been doing this with my '02 SSEi everyday for the last two weeks and it's started everytime. When it gets cold, it seems to take longer for the security to read the key.
PostPosted: Fri Nov 30, 2018 12:58 am
Yes, you're right on the money. It prevents the key from being turned all the way to the OFF position allowing it to be removed when the shift lever isn't in PARK.
There are no new unread posts for this topic. No Crank, No Start
02BlueR6
Mon Jul 04, 2011 8:31 pm
02BlueR6 View the latest post
There are no new unread posts for this topic. 01 sle crank but no start
bmoseman
Sun Feb 03, 2013 7:56 pm
There are no new unread posts for this topic. NEED HELP! CRANK NO START! P0300
EXLINE
Fri Jan 18, 2013 6:45 pm
EXLINE View the latest post
There are no new unread posts for this topic. 2001 bonneville ssei crank, no start
dematka
Mon Jul 16, 2012 5:33 pm
There are no new unread posts for this topic. Very strange no crank / no start on 2000 Bonneville SE
chevychev
Thu Jan 24, 2013 1:41 pm
chevychev View the latest post
Users browsing this forum: Google Adsense [Bot], Majestic-12 [Bot] and 13 guests
