It is currently Sat Jun 06, 2020 1:26 pm
 Post subject: 2001 SE Died
PostPosted: Mon Sep 17, 2018 8:58 pm
Well, not a good day.
Proceeded to leave work, like 90 degrees out, drove 1/4 mile and the car stalled.
I tried to start it and it would barely run....run horrible...die....
I put my foot into the accelerator pedal and got it into a parking lot...then it died again.
Just had it towed 50 miles home.
So when I was waiting for a tow, I got it running, however the RPM's were all over the map...running very rough and STRONG smell. A smell like I never smelled.....
Any clues where I should start?
No codes.
 Post subject: Re: 2001 SE Died
PostPosted: Mon Sep 17, 2018 9:35 pm
for starters, unplug the maf sensor and see if it helps
strong smell of what, gas?
PostPosted: Mon Sep 17, 2018 10:30 pm
What does your oil look like, and is your coolant level normal?
PostPosted: Tue Sep 18, 2018 8:04 am
Hello,
Oil is full and clear. Coolant is at the top of radiator and orange (I think its supposed to be orange).
The smell was very bad exhaust...almost like sulfur, but not quite.
When the tow truck delivered my car, 3 hours later, it started right up...WTH?
I have heard a ton of issues with MAF sensors and never thought it would happen to me...if this in fact is the issue.
I was thinking about buying some MAF cleaner and try again.
PostPosted: Tue Sep 18, 2018 9:10 am
ok, stupid me did not unplug MAF. I unplugged whatever the sensor is in the rubber plenum.
I'll unplug MAF when I get home tonight.
PostPosted: Tue Sep 18, 2018 9:20 am
Year and Trim: 2004 GTO
Could be clogged cat.
-Ryan
2004 GTO....LS1, 6MT
yourgrandma wrote:
Hi.
PostPosted: Tue Sep 18, 2018 9:28 am
If you're double certain your oil and coolant are fine, then that rules out the upper intake failing.
Otherwise, I'd check the MAF. You can check for a clogged cat by tapping on it with something, it'll rattle a bunch if it's bad. Could also be a crank position sensor.
PostPosted: Tue Sep 18, 2018 1:25 pm
I replaced the upper intake last year.
I'll check MAF tonight. I bough a Crank Sensor at lunch in case MAF checks out good.
PostPosted: Tue Sep 18, 2018 3:37 pm
yes, unplug the maf - it has a,b,c on top and a 3 wire plug
you unplugged the Iat - intake air temperature
the maf uses iat and map sensors to calibrate flow
PostPosted: Tue Sep 18, 2018 5:45 pm
Its my MAF. Runs unplugged and kills motor when I plug it in.
What sucks...Andrew is out of town for a while.
Is it worth the risk to junk yard it or buy the $140 Hitachi?
PostPosted: Tue Sep 18, 2018 7:13 pm
GET SOME MAF CLEANER, maybe its all dirty. - 10 bucks lasts 5 years
PostPosted: Wed Sep 19, 2018 7:54 am
Yes, I actually bought some cleaner yesterday and wasn't successful.
I ordered a new MAF from Amazon...$78.00...it will be here Thursday.
I'm going to junk yard at lunch as I need a quick MAF until my new one arrives (Go to night school).
Can I assume Buick MAF will also work - 2000-2005?
PostPosted: Wed Sep 19, 2018 4:13 pm
you can drive with maf unplugged for a while: just dont punch her - keep under 2500rpm
all 3800 series 2 have the same maf - just dont use the supercharged with a n/a engine.
PostPosted: Wed Sep 19, 2018 4:32 pm
Thanks.
Picked up a few..
There are no new unread posts for this topic. 2001 SSEI Died on me.
Tobiasjames
12
802
Sun Dec 24, 2017 11:40 am
96 SSEi View the latest post
There are no new unread posts for this topic. 02 SLE just died...
Z85
Mon Apr 01, 2013 7:32 pm
Z85 View the latest post
There are no new unread posts for this topic. Engine died while driving
AJT2004
Sat Jun 02, 2012 3:19 pm
AJT2004 View the latest post
There are no new unread posts for this topic. oh great, tranny just died
yourgrandma
29
2282
Tue Dec 27, 2011 4:48 pm
Jrs3800 View the latest post
There are no new unread posts for this topic. Heater core died....
Zeik75
Sun Jul 20, 2014 12:05 pm
bobgto65 View the latest post
