It is currently Wed Jan 23, 2019 9:51 pm
 Post subject: Sunroof stopped working
PostPosted: Sat Sep 15, 2018 9:19 am
Year and Trim: 2001 Pontiac Bonneville SSEi
How Can I fix this issue? I tried asking on Facebook but that didn’t help much. The sunroof switch when use works but when I use it, there is a buzzing noise. Window won’t move at all.
1997 Pontiac Bonneville SSE (TOTALLED! gone, but not forgotten!)
1993 Pontiac Bonneville SSE SUPERCHARGED (no comment)
1993 Pontiac Bonneville SSEi (sold)
1996 Pontiac Bonneville SSEi (sold....**sniff**)
2001 Pontiac Bonneville SSEi 106K (I'm back in black....YAAAAAY!!!!)
PostPosted: Sat Sep 15, 2018 11:49 am
Some plastic part of the track assembly is broken, jamming it up. There is no fix other than replacement of the entire assembly, which requires removal of the headliner, interior trim and likely the seats.
-Andrew-
PostPosted: Sat Sep 15, 2018 12:25 pm
Why do the seats have to come out
PostPosted: Sat Sep 15, 2018 6:47 pm
It is possible to leave them in there, but you'll probably damage your headliner trying to remove it.
-Andrew-
PostPosted: Sat Sep 15, 2018 8:20 pm
I've had my headliner out several times with the seats in. There is a technique to it, and it comes out the right rear door. As Andrew says, there is a risk of damage if not done exactly correctly. Part of this is that both front seats need to be in just the right position. If you are looking at the side of the right rear door opening from outside, you need to adjust the front passenger seat to maximize the size of the opening from the top left to the bottom right (where the front seat back and 'B' pillar form a "V". In or out, make sure you have clean hands when touching the headliner (especially with the taupe interior).
Red arrow shows area where the headliner needs to pass through. Adjust seat accordingly. Help is never bad to support the headliner while it's being turned and moved.
PostPosted: Sat Sep 15, 2018 11:22 pm
For the 5-10 minutes it takes to remove the seats, you'll save that time in trying to get it out undamaged.
-Andrew-
PostPosted: Sun Sep 16, 2018 12:14 am
It may not take long to get the seats out, but when you're old like me and your back hurts from carrying rotund people your whole career, speed isn't everything and taking the time to be super careful is worth it ;)
There are no new unread posts for this topic. Sunroof stopped working.
asuber
Tue Jul 01, 2014 12:16 am
cdog1463 View the latest post
seekinhighhp
Wed Dec 31, 1969 8:00 pm
Guest View the latest post
There are no new unread posts for this topic. power locks and power sunroof all stopped working ?
SPLLOUDER
Fri Aug 24, 2012 11:56 am
There are no new unread posts for this topic. Remotes stopped working
IABeancounter
Sun Nov 14, 2010 10:49 pm
There are no new unread posts for this topic. interior lights stopped working
bonneville dan-o
Tue Mar 03, 2009 4:56 pm
93RedSled-SSE View the latest post
