It is currently Mon May 20, 2019 7:18 am
 Post subject: 2001 Wheel Hop
PostPosted: Thu Sep 13, 2018 9:43 am
Hello-
New issue. After new struts, stabilizer links, sway bar bushings I now have a horrible wheel hop.
When I hit bumps in the road the front end "wanders"....
Any idears????
 Post subject: Re: 2001 Wheel Hop
PostPosted: Thu Sep 13, 2018 11:03 am
what struts did you use?
when you torqued strut to knuckle, was the car on the ground or off?. with the load on suspension, everything should line up nicely. without load, it could get wonky.
PostPosted: Thu Sep 13, 2018 11:43 am
I used the not so good all in one assembly struts.
I torqued nuts while suspended in air.
Anything I can do (other than diff struts) to help?
PostPosted: Thu Sep 13, 2018 12:02 pm
The problem with the quick struts is they raise the front end way high, making the suspension and axle geometry all messed up leading to all kinds of weird problems.
I'd get rid of those things if you still can. It'll never work as intended with them.
PostPosted: Thu Sep 13, 2018 12:51 pm
I was afraid you were gonna say that....Detroit Axle (AKA China).
I just sent them an e-mail.
What can you recommend that wont break the bank?
PostPosted: Fri Sep 14, 2018 6:43 am
I used KYB struts, my old springs, and Moog mounts.
PostPosted: Fri Sep 14, 2018 7:06 am
Year and Trim: 2003 SSEi
1999 Park Ave. Ultra L67
Try your original springs on the new strut assemblies, then have alignment checked
There are no new unread posts for this topic. wheel hub assembly/steering wheel positioning sensor
All Things Gxp
11
1773
Fri Sep 03, 2010 2:40 pm
All Things Gxp View the latest post
There are no new unread posts for this topic. Rattle in wheel after wheel hub replacement
Bonne1se
15
2089
Tue Aug 03, 2010 12:22 pm
Bonne1se View the latest post
There are no new unread posts for this topic. 2001 SLE Tune-up
dougtoth
Thu Sep 29, 2016 1:56 pm
There are no new unread posts for this topic. 2001 v 1996 MAF
jddem
Mon Sep 26, 2016 10:01 pm
jddem View the latest post
There are no new unread posts for this topic. Help with my 2001 bonneville
daddy-o
21
10871
Mon Sep 20, 2010 5:52 am
daddy-o View the latest post
