It is currently Tue Jan 22, 2019 5:29 am
PostPosted: Tue Sep 11, 2018 5:09 pm
Year and Trim: 2005 SE
Hey guys. What's the size and tooth count, or what hub adapter did you use for 6 bolt steering wheels? I've found that gm typically uses 1/2" 36 tooth splines for their wheels.
2005 SE Full Custom Audio System (By me)
Factory Pontiac Wheels Custom Powder Coated
Halo Retrofit Headlights
PostPosted: Tue Sep 11, 2018 6:24 pm
What are you trying to do, just remove the steering wheel?
-Andrew-
PostPosted: Tue Sep 11, 2018 6:53 pm
I'm trying to replace it. The OEM one is pretty worn and leaves sticky residue on my hands when driving.
PostPosted: Wed Sep 12, 2018 9:45 am
Trying wiping it down with a heavy duty degreaser like Simple Green, you might be amazed.
The simple way to remove the steering wheel:
Remove the airbag, horn and airbag wiring, and steering wheel wiring (if you have it)
Use a 21mm socket to loosen the nut, but don't fully remove
Grab the steering wheel and shake it back and forth like a crazy person. It should pop free in 4-5 pulls. The nut you left on will keep the steering wheel from hitting you in the face and/or damaging the wires.
Once its loose, remove the nut the rest of the way and fish the wires out of the steering wheel.
-Andrew-
PostPosted: Wed Sep 12, 2018 3:53 pm
Yep I got that, but what is the size and tooth count of the column? I have a GM adapter but i'm not sure if its the right size. The one I got is 3/4" 36 tooth for GM, Buick, Pontiac, Chevy.
PostPosted: Wed Sep 12, 2018 6:02 pm
36 tooth is correct, but I measured the shaft closer to 5/8".
-Andrew-
PostPosted: Thu Sep 13, 2018 12:16 pm
Thanks. Is there a link somewhere that I can find one at? i'm having trouble locating one.
PostPosted: Sun Oct 07, 2018 8:00 pm
bump
There are no new unread posts for this topic. wheel hub assembly/steering wheel positioning sensor
All Things Gxp
11
1694
Fri Sep 03, 2010 2:40 pm
All Things Gxp View the latest post
There are no new unread posts for this topic. Steering wheel
samples08
Sat Feb 08, 2014 7:37 pm
1tinindian View the latest post
There are no new unread posts for this topic. What does your GXP steering wheel look like?
cooljoe51
Mon Sep 09, 2013 9:16 pm
cooljoe51 View the latest post
There are no new unread posts for this topic. steering wheel not locking on 03 SLE
Villainville
Sun May 17, 2009 1:00 pm
ddalder View the latest post
There are no new unread posts for this topic. How much steering wheel play?
dayton.reed
Sun Dec 04, 2011 1:03 am
