It is currently Tue Jan 22, 2019 4:15 am
PostPosted: Fri Sep 07, 2018 7:48 am
Year and Trim: 2000 SE
2002 SSEI
Need some help, chasing my tail, sorta. I have completed the series III supercharged (L32) swap :banana: to my 2002 bonny in place of my knocking L67 #-o
I'm getting a rough idle once it goes into closed loop with no codes until last night. Finally got a P0172 code. I've checked for intake leaks, replace both o2 sensors, MAF sensor, had the exhaust leak repaired and so on. Running L32 EVAP Solenoid, everything else is L67 sensors and TB with ZZ adapter.
Do I need to replace my OEM ECM with one from ZZ performance that has been updated for the bigger supercharger? I currently have it scheduled to replace the lower and upper intake gaskets because I thought maybe an internal coolant leak is what might be causing the stumbling idle once it goes into closed loop. I did notice that when I accelerate that the Long Term FT seems to settle in at -17.969% and doesn't change until I let off the gas. I would have expected that to continue to move around?
Here is the freeze frame data.
Freeze frame information:
Fuel Status = 0 byte
Engine Load = 11.765 %
Engine Coolant Temperature = 181.4 °F
Fuel Trim Bank 1 Short Term = -0.781 %
Fuel Trim Bank 1 Long Term = -17.969 %
Intake Manifold Pressure = 10.733 psi
Engine RPM = 1,593 rpm
Speed (OBD) = 59.652 mph
Mass Air Flow Rate = 30.17 g/s
Throttle Position(Manifold) = 11.373 %
Any help to try and narrow this thing down would be greatly appreciated.
PostPosted: Fri Sep 07, 2018 7:56 am
10.7psi manifold pressure, at 11% throttle? Am I reading that right? If so, that sounds wrong.
PostPosted: Fri Sep 07, 2018 8:03 am
2002 SSEI
I'm assuming that is what the sensor is telling the ECM. I'm using the L67 MAP. Should I be using the L32?
I think I've answered my own question here. I looks like the L32 MAP sensor has a different type connector than the L67, so I'm assuming that I'm correct in using the L67 MAP.
PostPosted: Thu Oct 04, 2018 9:36 am
2002 SSEI
Well, found the source of my stumbling idle :bwoohoo: after inspection of the new spark plugs, cylinder 3 look like it was rich. Changed the fuel injector and all seems better. Guessing it was leaking.
Probably should replace all of them! :roll:
There are no new unread posts for this topic. Odd stumbling...
Z-type
Fri Jun 01, 2012 10:44 pm
bc21 View the latest post
There are no new unread posts for this topic. Engine Stumbling
jedwards83
Mon Feb 14, 2011 12:19 am
Ken_W View the latest post
There are no new unread posts for this topic. Stumbling problem
chophillies
Thu Aug 28, 2014 8:13 am
There are no new unread posts for this topic. Stumbling under low RPM / high load
jedwards83
Mon Jul 11, 2011 10:29 pm
There are no new unread posts for this topic. ITS BACK AGAIN hesitating and & stumbling
1997SEgreenmonster
Sat Oct 26, 2013 6:55 am
cooljoe51 View the latest post
Users browsing this forum: No registered users and 15 guests
