It is currently Tue Jan 22, 2019 3:52 am
 Post subject: 00 Bonnie SSEI Acc. Belt
PostPosted: Wed Sep 05, 2018 10:08 pm
So I'm trying to be certain all my things are in order.
Recently replaced water pump and needed a new main/acc belt.
Got 900K6 from autozone. Matched the same size as the one that was previously on.
I can't for the life of me with tensioner all the way loosened get whatever pulley left on. Generally my alternator is what I place on first. The supercharger belt is on its snug. This main belt is nightmare.
This is the belt their system showed for mines. Should I be following this? engine/topic2652.html
I didn't see a spacer but. I may have overlooked I guess.
PostPosted: Thu Sep 06, 2018 10:10 am
I think the 95-99 Series 2 3800s were different than the 2000+. I hate to ask the obvious question, but are you double certain it's the correct routing?
PostPosted: Thu Sep 06, 2018 12:21 pm
I am certain I'm following the right routing. Even pulled up other diagrams o line and in online PDF.
https://www.google.com/search?q=2000+po ... vHECSPpYcM:
PostPosted: Thu Sep 06, 2018 2:37 pm
Year and Trim: 2004 Buick Park Avenue Ultra
Just did this on my 04 PAU, it was admittedly a bit tough to get around the tensioner but when I was able to it sort of fell into place with the grooves. Make sure your following the correct pulleys and that you're not hung up at an angle on the main drive pulley at the bottom.
I found a helpful diagram here:
https://www.thechicagogarage.com/forum/ ... grams.html
PostPosted: Fri Sep 07, 2018 1:08 pm
No worries got the belt on. The one I told them I needed but swore I didn't and they gave me the wrong one. Swearing their system said it fit, turns out their site disagrees. Got the right one it's on now. Just gotta figure out this last Bolt for the water pump now, it's blocked by a pulley.
PostPosted: Fri Sep 07, 2018 2:10 pm
For future reference the correct belt for the accessory drive is a 925 length, the supercharger belt is a 725.
-Andrew-
There are no new unread posts for this topic. 2000 SSEi Supercharger Belt
Red Rocket
16
5324
Sun Jan 16, 2011 1:24 pm
a_kraker99 View the latest post
There are no new unread posts for this topic. Can my wife drive her SSEI with the supercharger belt OFF?
mrrcom
Mon Jun 02, 2014 5:05 pm
There are no new unread posts for this topic. How hard is it to change the serpentine belt on a 2002 SSEi?
Hailey
Fri Oct 22, 2010 5:32 pm
Hailey View the latest post
There are no new unread posts for this topic. Lower SEAT BELT LATCH for 2001 SSEi?
wug
Fri Nov 11, 2011 2:05 pm
wug View the latest post
There are no new unread posts for this topic. Chirping from S/C belt system after new belt & tensioner
2000GreySSEi
Fri Jan 21, 2011 11:11 am
2000GreySSEi View the latest post
