It is currently Tue Jan 22, 2019 3:51 am
 Post subject: Climate control
PostPosted: Wed Sep 05, 2018 9:44 pm
I've been having an issue with my climate control, it only works on full heat (90 degrees) or full cold (60 degrees) anything in between it's not accurate. Is there a thermostat or temperature sender that could be faulty? Any help would be greatly appreciated. Thank you
240k, Cleared Corners, Silverstars, Yellow 893 fogs, LED Marker,
Reverse & interior bulbs, L32, Triple Edge
transmission, Intense FWI, N*, GXP Brake & Swaybar Swap, Pacesetters
 Post subject: Re: Climate control
PostPosted: Wed Sep 05, 2018 11:15 pm
It could be the temperature blend door actuator messing up on you. Andrew probably has one and might know more about the issue.
PostPosted: Thu Sep 06, 2018 5:52 pm
ok clarification requested...are you saying the fans only work when you max the temps out and it forces them on the highest speed setting? and if you set it at another temp in between and manually adjust the fans to highest setting do they come on?
3.8L V6 SC, 180*T (Drilled),
PostPosted: Thu Sep 06, 2018 8:46 pm
When it's cold outside and i turn it on it blows cold air, if i turn the car off and back on again it will blow hot. But if i set it to 70 degrees and its cold outside it usually blows cold air. I doesn't keep the temperature i set.
PostPosted: Thu Sep 06, 2018 9:15 pm
ok, so not a fan speed issue, let me see what I can dig up
There are no new unread posts for this topic. climate control.
shredthebonnie
Tue Oct 20, 2009 9:51 pm
Black Pearl View the latest post
There are no new unread posts for this topic. climate control issues
azmedic85308
Wed Sep 03, 2008 5:50 am
azmedic85308 View the latest post
There are no new unread posts for this topic. 00+ automatic climate control
bonnevillain
Sat Apr 25, 2009 10:24 am
There are no new unread posts for this topic. Climate Control Issue
white06lacrossecxs
12
1226
Mon Jul 20, 2009 1:54 am
white06lacrossecxs View the latest post
There are no new unread posts for this topic. Climate Control might not be working
viper79
Tue Mar 08, 2011 3:43 am
viper79 View the latest post
cron
