It is currently Tue Jan 22, 2019 4:27 am
PostPosted: Wed Aug 29, 2018 6:51 pm
Year and Trim: 2000 Pontiac Bonneville Ssei
Installed zzperformance short stack intercooler and car whines load and shuts right down. Gave a little gas a fuel injector popped out! Pulled supercharger off and half of the boost bypass hole going down supercharger was blocked by I/c aluminum, other half blocked by gasket. Cut out gasket to expose half hole, reassembled with same results. Took off again and hole similar in size and opposite the pcv valve was blocked by gasket. Cut out reassembled with same results. ZZP wasn't much help and just said they've never had an issue. The I/c core extends past the manifold opening to cover half of bypass hole. I looked at pixs of ported manifolds and it appears as if it's ok for all the air ports to share the same space. I think in need to port out the metal between the hole that takes in air from supercharger to the boost bypass hole to allow more air to the bypass hole. I don't think it's getting an accurate reading being half blocked off by aluminum. Any thoughts?
3.4 pulley, Summit 9" cone FWI, ZZP coils and wires, 35/35 D&D gears, ZZP 1.0 pcm. (Intercooler in the works.)
There are no new unread posts for this topic. 2000 ssei p/s issue
kaotikd
Mon May 25, 2009 1:14 pm
rrounds View the latest post
There are no new unread posts for this topic. 2000 bonneville se brake issue
mrviper
Mon Jul 06, 2015 1:46 pm
mrviper View the latest post
There are no new unread posts for this topic. 2000 SSEI Spark Plug Replacement Issue
SSEI2000
Mon Oct 10, 2011 1:28 pm
SSEI2000 View the latest post
There are no new unread posts for this topic. Suspension issue on '00 Bonneville SSEi
likeamojay
Tue Sep 29, 2009 11:36 pm
There are no new unread posts for this topic. 2000 Bonneville ssei
lrollins26
Fri May 15, 2015 8:45 am
96 SSEi View the latest post
Users browsing this forum: Exabot [Bot] and 17 guests
cron
