It is currently Tue Jan 22, 2019 4:27 am
PostPosted: Sat Aug 25, 2018 8:39 am
Year and Trim: 2004 SE bonneville
anyone ever change the evap purge soleniod on a 2004? found the canistor but dont see the purge. could it be inside the canistor? also anyone's thoughts on cost to replace brake lines from front to back? (figuring shop labor) dosent look to bad if its on a lift. any help is appreciated. thanks in advance.
PostPosted: Sat Aug 25, 2018 6:46 pm
The purge solenoid for the 3.8L engine is in the engine compartment, not near the canister underneath the vehicle. I don't have a picture, but the shop manual shows it underneath the engine cover in fairly close proximity to the coil packs. The GXP has it located under the vehicle near the canister.
PostPosted: Sat Aug 25, 2018 8:06 pm
Year and Trim: 2000 SLE 2005 SLE
1975 Monte Carlo
It is a black cylinder looking thing about 2-3 inches long with a couple of vacuum lines coming out of it.
It is just left of the coils right in the front.
I have changed a couple but be careful taking the lines off of it.
One of the lines has a special U shaped design that you can only get from GM.
PostPosted: Sat Aug 25, 2018 9:12 pm
thanks fellows appreciate the help.
There are no new unread posts for this topic. EVAP Purge Valve troubles need advice.
MrJiggy716
Sun Nov 03, 2013 6:33 pm
95se View the latest post
There are no new unread posts for this topic. EVAP vent location.
01bonneSC
Fri Oct 31, 2008 11:20 am
slick94prix View the latest post
There are no new unread posts for this topic. O1 SSEi EVAP Canister Location
spoiledred94
Fri Jun 22, 2012 6:02 pm
There are no new unread posts for this topic. 2000 SE Canister Purge Solenoid / Purge Valve
Merrillspontiac
Wed Apr 05, 2017 9:04 am
There are no new unread posts for this topic. P0420 and P0440 - Canster Purge or Canister Vent Soleniod?
IABeancounter
Tue Jul 12, 2011 1:26 pm
Archon View the latest post
Users browsing this forum: Exabot [Bot] and 17 guests
cron
