It is currently Fri Apr 26, 2019 6:55 am
 Post subject: Shifting issues
PostPosted: Thu Aug 23, 2018 11:32 pm
Year and Trim: 2001 SSEi
My SSEi had been parked for awhile and get her back up and running, however now she is sluggish on take off and having trouble shifting unless I let off the gas (almost like a clutch). Starts to run better once it is through the first few gears, but it is a task getting there. Any thoughts?
 Post subject: Re: Shifting issues
PostPosted: Fri Aug 24, 2018 8:59 am
How's the fluid color and level?
-Andrew-
PostPosted: Fri Aug 24, 2018 12:40 pm
After I posted this, I realized I probably left out a couple key points:
1. the car has 92,000 miles on it
2. trans fluid seems like a healthy pinkish red
3. trans fluid level, if anything, is a little high
I considered changing the fluid, but since it was not brown or dark in color it seems like it may be more risk than gain (reading all the back and forth about to flush or not to flush).
PostPosted: Fri Aug 24, 2018 2:04 pm
A fresh filter can go a long way sometimes. I'm not a fan of flushes either, but dropping the pan, replacing the filter, and refilling is pretty benign in that regard.
PostPosted: Fri Aug 24, 2018 2:37 pm
I thought about that and figured it could not hurt, just was not optimistic about it solving the problem.
Any suggestions on the flooding of the trunk? I know my tail lamps have de-laminated and holding water and I am looking to replace them, but they are next to impossible to find brand new and I can't believe that much water is coming in from the tail lamps. I event took the spoiler off and put rubber washers on them and it is still happening.
There are no new unread posts for this topic. Shifting issues
terrancew3
Fri Feb 07, 2014 6:32 pm
There are no new unread posts for this topic. HELP! Oil Pressure issues/ Knocking/ Boost issues
Renegade
Thu Jun 05, 2014 7:31 am
Renegade View the latest post
There are no new unread posts for this topic. Shifting problem.
darwinm
Fri Nov 14, 2008 9:42 pm
Whitecrystal1 View the latest post
rudydog
Fri Apr 03, 2015 12:45 am
There are no new unread posts for this topic. Transmission Shifting
Tight
Fri Apr 08, 2011 9:29 am
Archon View the latest post
Users browsing this forum: Google [Bot] and 10 guests
