It is currently Mon Feb 18, 2019 9:06 pm
Post new topic Reply to topic  [ 18 posts ]
 Post subject: 2001 SE Front Axles
PostPosted: Thu Aug 23, 2018 1:33 pm
I just took my 2001 SE in for an alignment. I just changed struts, links and sway bar bushings.
I told them I had the 70 MPH death shake.
They said I need both front axles and new motor mounts.
It also just started to shake upon acceleration.
How much work is changing front axles and motor mounts?
Can that cause my shakes?
 Post subject: Re: 2001 SE Front Axles
PostPosted: Thu Aug 23, 2018 10:42 pm
First, just change the front motor mount. You can either replace it with an OEM style mount, but they're known not to last. Or talk to Andrew about getting a boat roller mount, which is much more durable.
Either way, replacement is easily done under an hour, even your first time.
PostPosted: Fri Aug 24, 2018 8:07 am
Thanks,
Can a bad motor mount cause shaking?
PostPosted: Mon Aug 27, 2018 8:07 am
I wish I knew how to upload pics.
Upon investigating the condition of my motor mount, ALL 3 bolts holding front motor mount bracket to engine were missing.
Thank God I had bolts at work. Jacked up motor in parking lot, new bolts, good to go.
PostPosted: Mon Aug 27, 2018 10:56 am
Easiest way to upload pics is make an Imgur account, upload them there, and then post the IMG code into the forum box here.
When my OEM style front mount was worn out, it caused shaking while accelerating and a persistent shake at highway speeds. Replacing an axle is way more involved than the motor mount, so always start with the easy and cheap methods/fixes.
PostPosted: Mon Aug 27, 2018 12:28 pm
Honestly, I really owe you a case of beer and a big thank you.
If you didn't mention the motor mount I would have never looked.
Send me your email address and I'll send you the pic.
Thanks,
Lee
elliottlee2@yahoo.com
PostPosted: Tue Sep 04, 2018 9:12 am
New issue -
Changed the front mount with no issues.
However when I was under car I saw there was grease everywhere!! My first thoughts were split CV boot. There was even grease sprayed on the coil pack.
I cant find a cut anywhere!
Any suggestions?
PostPosted: Tue Sep 04, 2018 12:28 pm
check that the boots are nice and round - once, a rag got caught in mine and squeezed the grease out but boot was intact but not round like the other side- if grease is on coil pack, I would inspect the pass side boot.
PostPosted: Tue Sep 04, 2018 1:29 pm
I looked at lunch. Definitely the passenger side.
Here's what I think happened.
Last week when I installed new struts I think I let the knuckle hang too low and possibly pulled the boot away from shaft. Tonight I'll see if I can push the silver band back on more.
Problem is...how do I re-pack the boot with CV grease if that's the case?
PostPosted: Tue Sep 04, 2018 3:11 pm
you have to remove it(axel) and then there os one large bolt that removes the end - then you remove, repack and install - or you can get a zipper/glued kit - https://www.amazon.ca/Dorman-HELP-614-6 ... 9826&psc=1
IS it outter or inner boot?
PostPosted: Tue Sep 04, 2018 3:20 pm
It's the large one closest to center of engine.
PostPosted: Tue Sep 04, 2018 3:48 pm
so, inner, yes, remove whole axle and replace the boot
PostPosted: Wed Sep 05, 2018 10:28 am
Thanks
PostPosted: Wed Sep 05, 2018 11:35 am
np, yes, when I had the collapsed boot, the mechanic wanted to change whole axle - I said why, just the boot is kaput - he says well, people just change the whole axle
so beware of uneeded work
PostPosted: Wed Sep 05, 2018 2:14 pm
I have a bad shake on acceleration, I think the axle shaft is bad anyway.
PostPosted: Wed Sep 05, 2018 3:20 pm
Year and Trim: 2000 SLE 2005 SLE
1975 Monte Carlo
It's possible that if it ran long enough without grease you might have ruined the metal joints.
I would just put a new axle shaft on.
They are not that expensive.
PostPosted: Wed Sep 05, 2018 4:08 pm
Yeah, hope to get er done in the next day or so. Thanks
PostPosted: Fri Sep 07, 2018 6:48 pm
get it off the ground and put in drive and idle idle( up against a strong wall) and you will see if its bent and which one -
There are no new unread posts for this topic. 2001 SSEI Front Axles
dougtoth
Tue Oct 09, 2018 9:43 am
dougtoth View the latest post
There are no new unread posts for this topic. Front Axles
vogie01
Mon Jan 02, 2012 2:56 pm
vogie01 View the latest post
There are no new unread posts for this topic. Can you put a license plate on the front of an 2001 S.E.?
walnut777
Thu May 16, 2013 10:06 am
Sirius View the latest post
There are no new unread posts for this topic. Looking to purchase 2 front tires for my 2001 sle
Franksdad
Sun Feb 03, 2013 12:45 am
There are no new unread posts for this topic. Replacing the front hub assembly on a 2001 Bonneville SSE
bowms76
Fri Nov 08, 2013 9:19 pm
bowms76 View the latest post
Users browsing this forum: No registered users and 14 guests
