It is currently Sat Jul 20, 2019 4:34 pm
Post new topic Reply to topic  [ 19 posts ]
PostPosted: Wed Aug 08, 2018 6:42 pm
hi all, my S/C is making the rocks noise but with the belt off, there is no play when I turn the pulley - is this common and is it that little sprocket that needs replacement?
PostPosted: Wed Aug 08, 2018 7:05 pm
Run it for a minute with the sc belt off. Is the noise still there?
PostPosted: Wed Aug 08, 2018 10:13 pm
no I have been running about 500 klm with no belt for s/c and no rocks
PostPosted: Thu Aug 09, 2018 1:47 pm
well?. does anyone have insight?
PostPosted: Thu Aug 09, 2018 1:51 pm
Any grinding when you turn the pulley? That would point to a bearing. There are nose drive bearings, rotor plate bearings, and needle bearings on the intake end.
PostPosted: Thu Aug 09, 2018 1:57 pm
no, no grinding, no play and it spins smoothly.....thanks
PostPosted: Fri Aug 10, 2018 12:19 am
Have you checked the idler pulley & the tensioner pulley on the SC belt train?
It is very common for bearings in these to go bad.
PostPosted: Fri Aug 10, 2018 1:20 pm
no, but it sounds like it comes from the blower....Ill check the tensioner,,,thanks
PostPosted: Fri Aug 10, 2018 8:43 pm
WELL, the pulleys are both spinning freely so the rocks are from the blower
PostPosted: Sun Aug 12, 2018 1:54 pm
ok, this may be easier to answer............if I drive with the s/c running and making the rocks noise - will it damage the blower or engine?
PostPosted: Sun Aug 12, 2018 2:20 pm
Well, it's not a good noise. These superchargers aren't known to catastrophically fail, but it has happened. I'd look into getting it fixed soon. My guess at this point is that it's the needle bearings. If you don't feel like replacing bearings, a used sc isn't super expensive.
PostPosted: Sun Aug 12, 2018 3:39 pm
OK, THANKS, where would I get those bearings if needed
PostPosted: Mon Aug 13, 2018 11:02 am
Year and Trim: '93 SSEi
'05 STS-4
'97 LeSabre
I think you can get all the parts you need to rebuild the supercharger on ebay in a kit? That might have just been for the nose, but the bearings are available on ebay for sure. The needle bearings in the case can be R&R'd without a press, but you can't R&R the nose bearings without a press.
I'd double check that the noise is not the harmonic balancer rubber failing. The noise can be similar to the blower rock noise when it first starts to fail, as is gets worse it starts sounding like rod knock. Most people don't really notice it until the rubber has completely separated from the center pulley, and you can freely move the belt back and forth a bit by hand when the motor isn't running. The last one that failed on me the rubber hadn't fully separated - the partial bond allowed it to not be moved by hand but still made the noise - which was confusing until I inspected the balancer.
Runs:
Doesn't run:
PostPosted: Mon Aug 13, 2018 1:03 pm
ok, thanks for input but I am positive the blower is making the noise - no noise when disconnected.
Im gonna start by changing the oil and see if the noise changes
PostPosted: Mon Aug 13, 2018 1:29 pm
Unless there's no oil in it currently, or it has cooked and congealed, the noise probably won't change.
PostPosted: Mon Aug 13, 2018 2:21 pm
I will diagnose as best as I can, not interested in idle chatter...thanks
PostPosted: Mon Aug 13, 2018 3:15 pm
I was trying to point out that changing the SC oil will likely be fruitless.
PostPosted: Tue Aug 14, 2018 7:10 am
Year and Trim: 2003 SSEi
1999 Park Ave. Ultra L67
I agree. Also, without the load of the supercharger, a balancer just begining to make noise may not make noise with the belt off. Try a stethoscope on each end of the supercharge with the belt connected.
PostPosted: Tue Aug 14, 2018 1:18 pm
'05 STS-4
'97 LeSabre
This was exactly what happened to me. What sounded like the supercharger ended up being the (newer) balancer.
Runs:
Doesn't run:
There are no new unread posts for this topic. Supercharger noise...nasty noise
Mac077
29
4766
Wed May 09, 2012 6:05 pm
Mac077 View the latest post
There are no new unread posts for this topic. Bong noise, not key in ignition or water bubbles noise
ratsbird
Wed Dec 19, 2018 2:46 pm
57j2olds View the latest post
There are no new unread posts for this topic. Thud noise and cracking noise when turning the wheel
llllcdllll
Thu Jun 30, 2011 2:37 pm
llllcdllll View the latest post
There are no new unread posts for this topic. Supercharger oil
Predaking_82
Wed Sep 25, 2013 12:17 pm
Wes View the latest post
There are no new unread posts for this topic. Supercharger Oil
Stadawim
Wed Sep 14, 2011 1:48 pm
Users browsing this forum: No registered users and 14 guests
