It is currently Sat Jul 20, 2019 4:40 pm
PostPosted: Fri Jul 27, 2018 1:52 pm
Year and Trim: '01 Bonneville SE
Hi,
I feel like I've read every post on this forum and others related to power windows/door lock/mirrors not working and I've learned a lot, but I still don't know how to determine if the DDSA or the DDM is the source of the problem; the other switches operate at their respective doors. I have 12v going into the DDSA on the orange wire and measure voltage changes on the orange/black and red/black wires when using the door lock switch (4.7v to 0v). I have 12v on the tan/white (Simple Bus Interace) when the car is off and 8v when the car is on.
I've got continuity on every wire I've tested, but I still don't know how to use any of this to say definitively if the DDSA or DDM is the problem. Does determining that require more than a multimeter?
Please help. Thank you.
PostPosted: Fri Jul 27, 2018 4:59 pm
if all the windows work at the doors, but not by drivers master, and if mirrors also nogo, then I would replace master with a working unit.
PostPosted: Fri Jul 27, 2018 5:08 pm
By master, are you referring to the driver door module or the switch assembly?
PostPosted: Sun Jul 29, 2018 1:25 pm
The DDM acts as a gateway between the Class 2 serial data bus and the SBI used for communication between the door modules. Without getting into a long drawn out explanation of what takes place when non-driver door controls attempt to open/close windows, the fact that they are working is very strongly suggestive that the DDM is fine and the DDSA is the problem.
PostPosted: Thu Aug 02, 2018 10:55 pm
Thanks for the response and sorry for the tardiness in my reply. None of the salvage yards around here have Bonneville's (which seems simultaneously good and bad), so I'm going to order a DDSA off of Ebay and let you know how it goes.
I completely disassembled my DDSA and didn't see anything out of the ordinary on my circuit board, but there is a section underneath a soldered-on heat shield that I can't see under. Nonetheless, I'm sure it could fail without any visible issues.
PostPosted: Mon Aug 06, 2018 2:55 pm
My apologies for not responding sooner, because Andrew (harofreak00), parts out 2000+ Bonnevilles and probably has a dozen or more on the shelf, ready to go. He's a great source of parts when you need them.
PostPosted: Fri Aug 10, 2018 10:28 pm
No problem. I installed the new DDSA and everything is back to normal! Thanks for the help!
PostPosted: Sat Aug 18, 2018 11:02 pm
Glad to hear it's back to normal again!
There are no new unread posts for this topic. Noisy hub, how to determine what side?
masher
Thu Sep 05, 2013 7:10 pm
There are no new unread posts for this topic. Trans Issue or Ignition/Fueling Issue(s)
WhiteArrow3800
15
1698
Wed Aug 26, 2009 11:11 pm
There are no new unread posts for this topic. A/C Issue
white06lacrossecxs
Wed Jul 06, 2011 1:44 pm
leatherneck View the latest post
There are no new unread posts for this topic. A/C issue
04bonnieee
Thu Apr 05, 2018 2:43 pm
04bonnieee View the latest post
There are no new unread posts for this topic. Maybe a MAF issue?
bluize3
Wed Jan 01, 2014 10:03 pm
