It is currently Tue Mar 19, 2019 3:19 pm
PostPosted: Thu Jul 19, 2018 9:10 pm
Year and Trim: 2000 SLE 2005 SLE
1975 Monte Carlo
Just bought a 2005 SLE last night.
The temperature gauge is not working.
Is it a bad stepper motor or maybe a sensor?
One more thing.
One of the fog lights is burned out.
On my 2000 SLE you just take out 2 bolts.
On this one it is boxed in.
Do you just drop the black panel that is held up with push pins?
Thanks.
PostPosted: Thu Jul 19, 2018 9:16 pm
Does the gauge sweep with the rest of the gauges properly?
What exactly is the gauge doing otherwise?
Are you receiving any other symptoms, such as a MIL?
PostPosted: Thu Jul 19, 2018 9:32 pm
1975 Monte Carlo
The needle just stays down on the low end (left side) and does not move.
There are some codes.
One was for the EGR Valve and the other is the P0442. (possibly bad gas cap)
My scanner is borrowed out but should have it back tomorrow.
I will let you know the codes tomorrow.
Thanks.
PostPosted: Thu Jul 19, 2018 11:55 pm
Year and Trim: 2000 SE. 2000 SSEi, 2001 SSEi, 2002 SLE
GM instrument clusters are junk. Most likely a bad guage if it isnt sweeping when you start the car.
For the fog light just drop that panel and the fogs are right there. I actually burn out so many fog light bulbs that I left that panel off the car now and can change them in less than a minute
PostPosted: Fri Jul 20, 2018 6:32 am
1975 Monte Carlo
Thanks for the information.
PostPosted: Fri Jul 20, 2018 11:50 am
Sounds like a bad stepper motor. The 2004 and newer clusters are known for issues with the steppers.
The fog lights on the GXP/2005 SLE style cars are known to go out frequently. Replace with LED or HID to keep them going longer.
PostPosted: Fri Jul 20, 2018 5:33 pm
1975 Monte Carlo
Do you know what the LED bulb number is?
Is it just plug and play?
Thanks.
There are no new unread posts for this topic. Coolant temp not working right
bigtoxi
Sat Oct 08, 2011 10:36 am
There are no new unread posts for this topic. Water Temp gauge
Mac077
Wed Jun 30, 2010 5:09 pm
Mac077 View the latest post
There are no new unread posts for this topic. Coolant temp gauge
ParkAve666
Sun May 27, 2018 4:28 pm
96 SSEi View the latest post
There are no new unread posts for this topic. 2005 SE Coolant Temp Sensor location
Mac077
Thu Apr 07, 2011 3:11 pm
There are no new unread posts for this topic. Engine Hot A/C disabled warning, high temp on gauge (update)
DbqJoe
20
7158
Wed Apr 04, 2012 10:16 pm
jedwards83 View the latest post
Users browsing this forum: Exabot [Bot] and 13 guests
