It is currently Mon Feb 18, 2019 8:50 pm
Post new topic Reply to topic  [ 15 posts ]
PostPosted: Mon Jun 18, 2018 3:08 pm
Year and Trim: 2000 se
Hey Guys got a 2000 3.8 that needs struts and the rear shocks are probably toast too? I don't hear the compressor kick on when i get inside the trunk etc, and it's really bouncy
otherwise, I tried to pull the relay out of the box up front, but it seemed stuck, as did others i tried too? Is there a certain way they come out? I usually just pull them and they come right out in other cars.I need to check for power at the compressor first also, I thought i read there's a button in the trunk to push to turn compressor on? I couldn't find it in my car? Also on the front's ive read about the complete units being taller then just replacing the strut itself, anyone used these? GABRIEL G57051, Do they also increase ride height?
Thanks!
PostPosted: Wed Jun 20, 2018 8:44 am
Year and Trim: 1993 SLE
1998 SE
2001 SSEI
2002 SSEI
This tool makes removal easier
https://www.amazon.com/ABN-Puller-Remov ... B0195PCN7S
No, there's no trunk switch to turn the compressor on for the shocks to inflate.
Check the wiring, as it may have broken or the connector corroded over the years.
On the SSEi there is a fitting for a hose at the edge of the trunk, so you can inflate the tires...... at a snail's pace.
PostPosted: Thu Jun 21, 2018 4:46 pm
Thanks for the reply! So I checked the connector with car running and unplugged , and I have power at one of the prongs, looks like the green wire? So I’m thinking compressor is toast? And looks like a bitch to replace etc where it’s at, next option just get some Gabriel high jackers and run new lines?
PostPosted: Tue Jun 26, 2018 10:12 am
What do u guys think of these?
https://www.ebay.com/itm/4-Shocks-Strut ... Sw-0RbA3db
PostPosted: Sat Jul 14, 2018 9:59 pm
So I've got a po300 code and when i had the key on today after hooking scanner up i heard the compressor, so that means its probably ok? And I can just put new shocks back in?
PostPosted: Sun Jul 15, 2018 11:13 am
Those eBay shocks will make the car ride high. I'd go with ACDelco stuff or KYB. They are tried and true.
P0300 is a multiple random misfire code and is unrelated to your rear suspension.
PostPosted: Sun Jul 15, 2018 12:30 pm
Thanks! What bout those Gabriel’s I listed above? The only reason I brought up the p300 code is cause I was using scan tool yesterday n that’s when I heard the compressor lol, I’d never heard it before so I thought it was *shoot*.
PostPosted: Wed Jul 18, 2018 6:09 pm
Year and Trim: 2003 SE
This is a dumb question that I can't find the answer to after lots of searching - do ALL 00-05 Bonnevilles have rear air shocks? Or just the SLE/SSEI? I have an 03 that I am shopping for rear shocks, and all that is available is air shocks.
PostPosted: Mon Jul 23, 2018 6:10 pm
Year and Trim: 2004 GXP
2003 SE
All 2000-2005 Bonneville's came factory with rear air-ride
PostPosted: Tue Jul 24, 2018 7:47 am
What's a GOOD quick strut for the front of our cars? I don't care if sets a little high, i know they settle, just don't want to waste my money on junk cheap ones
PostPosted: Tue Jul 24, 2018 8:34 am
No good quick struts for our cars. They all make the car ride goofy high and will not settle. Reason being is the extra coil quick struts have in the springs.
PostPosted: Tue Jul 24, 2018 9:10 am
How hard is it to compress that coil, I've got a internal compressor, not sure if it can be used as a external one? Install strut in vise and loosen top nut after compressing? So i ordered the Kyb strut, The moog upper mount and the kyb lower isolator, that should be it correct?
PostPosted: Tue Jul 24, 2018 2:36 pm
Pretty much. It's an easy process with either spring compressors or the wall mounted vice kind. Just take your time and be careful!
PostPosted: Tue Jul 24, 2018 4:19 pm
Thanks! O’reillys has one I can rent that’s for them.
PostPosted: Thu Aug 02, 2018 7:50 pm
Struts all done! Went great n it drives great, goodbye to the ship I was on lol!
There are no new unread posts for this topic. What shock for rear with front struts
imidazol97
Sun Aug 17, 2008 9:32 pm
Archon View the latest post
There are no new unread posts for this topic. Replaced Front Struts with Monroe Quick Struts
DCJREDLINE
26
5324
Fri Apr 06, 2012 9:31 pm
DCJREDLINE View the latest post
There are no new unread posts for this topic. Shocks and struts
Merrillspontiac
12
1914
Mon Jan 26, 2009 12:35 am
RookieSSei View the latest post
There are no new unread posts for this topic. Best way to tell you need new shocks/struts?
EWC88
16
6515
Wed Jan 20, 2010 2:48 pm
EWC88 View the latest post
There are no new unread posts for this topic. struts/shocks
Looong4
Thu Sep 11, 2008 1:10 am
Looong4 View the latest post
Users browsing this forum: Google [Bot] and 11 guests
